Old 10-08-2023, 07:42 AM
fenders74's Avatar
fenders74 fenders74 is offline
Default marker name......
Hi guys with the new eucontrol the marker name does not appera under cubase 12, I can memorize go to mark 1 but it dosen't reflect the name of marker 1.
With the past version I did
WIN 11 64 bit
Cubase 12
MC Mix and MC Control V2
EuCon 4.17.2.121
Eucontrol 2023.11.0.121
Old 10-11-2023, 01:00 PM
EddieJones's Avatar
Default Re: marker name......
You need to go to the softkey editor in EuControl and delete the Label and then save. (for each marker unfortunately)
Old 10-12-2023, 12:43 AM
fenders74's Avatar
Hi, do You mean to leave blank the description label space?
WIN 11 64 bit
Cubase 12
EuCon 4.17.2.121
Old 10-12-2023, 08:12 AM
EddieJones's Avatar
Correct...so they than can come down from the DAW
Old 10-12-2023, 08:46 AM
fenders74's Avatar
Hi....nope...the keys remains with no name.
The command is eucon----key commands----transport-----to marker1 and so on or I'm wrong?
WIN 11 64 bit
Cubase 12
EuCon 4.17.2.121
Old 10-12-2023, 09:33 AM
fenders74's Avatar
SOLVED!!
A little complicated but works.....I don't remembered how
WIN 11 64 bit
Cubase 12
EuCon 4.17.2.121
Elastic Audio "Remove Warp Marker" doesn't remove the warp marker yonkiman Pro Tools 12 3 10-25-2018 06:52 PM
shortcut needed: tab next marker/ prev marker Sir Hannes Getting Started 7 03-28-2018 09:01 AM
Keyboard shortcut for jumping from marker to marker... shotgunndunn macOS 1 11-28-2012 07:45 AM
How do I get rid of this marker? DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-14-2011 01:06 PM
Trying to set bar/beat marker, tempo marker won't conform maitredebas Pro Tools M-Powered (Win) 0 07-31-2009 07:31 PM
