Old 03-17-2023, 09:26 AM
peapodpost peapodpost is offline
Default PT Bounce to ADM vs Dolby Renderer ADM
Maybe someone knows the answers to the following. Couldn't quite tell from reading every doc I could find.
1. Are PT and DAR Home Theater version using the same engine underneath?
2 .What are the built in Pro Tools ADM bounce re-render defaults for:
  • LoRo vs ProLogicII(x)/(90 phase)
  • Direct Render vs with Room Balance
  • Limiter settings on the Re-renders
3. In the "Apply Program Level Metadata" menu, does that option simply refer to just the piece of metadata describing how the decode should happen down the line, and doesn't affect any audio processing in the resulting ADM?
Old 03-17-2023, 10:29 PM
coaxmw coaxmw is offline
Default Re: PT Bounce to ADM vs Dolby Renderer ADM
It says most of this in the reference guide ProTools is taking most of its info from the connected renderer by default. There is no ProTools default for question 2- you can choose the renderer default, the connected renderer settings or the settings from the most recent ADM imported into the session.
Program level Metadata is the trim, downmix, binaural modes etc.
Pro Tools Ultimate 22.7 ADM bounce Vs Dolby renderer PhiltheGreek1 Post - Surround - Video 0 10-06-2022 12:55 PM
Dolby Renderer with HD Native PCIe card its2loud Post - Surround - Video 2 08-26-2021 06:18 AM
Dolby Renderer and Big Sur? LewisP Pro Tools 1 08-16-2021 07:31 AM
Dolby Atmos Renderer dropping out of record Goombot Avid Pro Mixing General Discussion 2 07-28-2021 05:44 AM
Dolby Atmos Renderer file naming Branko Post - Surround - Video 6 03-01-2020 01:43 AM
