Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 07-25-2021, 09:19 PM
Goombot Goombot is offline
Default Dolby Atmos Renderer dropping out of record
I start to print an Atmos master file and about 15 seconds in each time the renderer drops out of record. Everything is locked. It stays in synch, I keep hearing audio but it drops out of record. No idea why. I looked on the Dolby site about this happening while using Dante (I'm using a MTRX Studio with HDX and the RedNet PCIeR Dante card) and everything they list as a possible issue I don't have. So as of now I can't print a master file.
Old 07-25-2021, 10:03 PM
its2loud its2loud is offline
Default Re: Dolby Atmos Renderer dropping out of record
Are you recording while Re-renders are turned on? If so, try turning them off. Also turn off binaural headphones output if that’s on too.
You can still make a master file if you do an offline bounce to ADM wave in Pro Tools. Then import the ADM file into the Renderer and export the Atmos files. You can also use the Dolby Conversion Toolkit for this.
Old 07-28-2021, 05:44 AM
kosmokrator kosmokrator is offline
I had this once recently while recording the DAMF onto a network share.
Switched to the internal SSD, everything worked.
No idea if this was a one-time glitch or if it would happen regularly while recording to a network share.
Atmos Renderer consultant? DaveGross Post - Surround - Video 12 07-25-2021 02:03 AM
Atmos Renderer buffer underrun oldskool Post - Surround - Video 0 04-08-2021 11:07 AM
Dolby Atmos Renderer file naming Branko Post - Surround - Video 6 03-01-2020 01:43 AM
Dolby Atmos Production Suite renderer on another computer nedd Post - Surround - Video 7 04-24-2019 08:11 AM
Atmos HT Renderer Norad155 Post - Surround - Video 0 04-02-2019 10:24 AM
