getting large files off PC to Mac
I somehow need to get some large files and folders off a PC Laptop onto my mac. The PC can't read any of my external drives so i'm looking for another way to do this! Even with a drive formatted to fat 32 i couldn't copy data larger than 4gig. Can i easily ethernet the computers together? Chris
Re: getting large files off PC to Mac
Chris - FAT32 has a file size limitation (I believe) of 4gb - (Which you're already aware of)
if you format that drive NTFS on the PC - the Mac will be able to "READ" the files, but not Write to the NTFS partition, and file sizes MUCH larger then 3Gb are supported. Once you've copied everything from the NTFS drive, you can Just reFormat it on OS X's disk Utility, to use with your Mac. if there are ALOT of files, lots of data, Copying over network / Ethernet will take forever, but WILL work, the NTFS formatted external drive is your quickest bet. if you WANT to write NTFS on your Mac, you can buy Paragon for $40.00 Bucks PARAGON which comes in handy for accessing and Write / Execute / Delete on NTFS Windows partitions, from your Mac. - but again, NOT necessary for this File transfer.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
FAT32 is limited to files of 4GB or smaller. Have you tried formatting the drive NTFS, copy the data to it, then bring it to the Mac - which should read it.
I beat you Digi. :)
Yes, problem is i would have to delete everything on one of my external drives to format it to NTFS! and they all have loads of data stored on them. Guess this is the only way! damn microshaft windblows Chris
Sure you can!!!
If you don't have a Switch or Router you could use a Crossover Cable Here's a good link for networking Mac and PC I usualy mount the Mac drives on the PC with Share Points Share Points allows you to Network any Drive or Folder Not just the start up!!!! http://joelandfaith.com/computer/mac/mxpfs.html And Sharpoints http://www.hornware.com/sharepoints/
The Greatest Risk in Life is Doing Nothing |
Or... you could try MacDrive7 on the PC allowing you to Mount, and read / Write all OS X volumes.
you could use one of your "Already Mac Formatted" drives right on the PC to Drag and Drop the files. I've used this in the Past, it worked really well on the PC
+1 for Mac Drive 7, and I'm pretty sure there's a long demo period, which would let you do the job without buying it
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
If you have Pro Tools on the PC side, you can install HFS+ off the installer, which is basically Macdrive.
-Justin
Justin Walker |
I need to learn to hit 'refresh' before starting my reply!
MP3 Files Too Large! | joseph halloran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2017 10:47 AM |
WAV Files too large? | MisterLbx | Pro Tools M-Powered (Mac) | 1 | 03-22-2012 06:35 AM |
LARGE Wav files per Song | KJVMBird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-09-2007 07:43 PM |
large files | Eilertsen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-15-2005 12:02 PM |
OT- taking large files from a PC to a MAC? | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-28-2003 07:25 AM |
