Old 08-21-2007, 07:20 PM
AbjectEvolution AbjectEvolution is offline
Default Updated TPkd Driver Required?
New system. Specs below. Installed Pro Tools. It says "Updated TPkd driver required and a reboot. Please reboot or re-install the software."
Gigabyte p35 ds3r Motherboard
EVGA 8800gts 640mb graphics card
2gig ddr2 ram
Core 2 Quad q6600 processor
M-Audio Delta 66 soundcard
EDIT: After clicking "ok", the box comes up again. After clicking "ok" a second time, it says this "Unable to locate M-Audio hardware. Make sure your hardware is connected and turned on". Well I hear sound and the icon is in the task bar so I know the soundcared is working. What's going wrong?
Old 08-21-2007, 07:45 PM
sunburst79 sunburst79 is offline
Default Re: Updated TPkd Driver Required?
I ran into A TPKD driver problem a while back and after uninstalling/reinstalling PT and ALL the plugs twice. The solution turned out to be that you first had to uninstall the existing TKPD driver and reboot, then install the new TKPD driver and reboot. While that may not be the solution to your problem thats what worked for me.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 08-22-2007, 09:47 AM
What is the tkpd driver? How do I un-install it before installing windows? Does it have anything to do with Pro Tools not seing my M-Audio soundcard?
Old 08-22-2007, 09:58 AM
DigiTechSupt's Avatar
The Tkpd driver is the name of the package installer for PACE system files. You can get the latest driver installer on the PACE website at www.paceap.com.
Avid Audio Tech Support
Support FAQ
Old 09-12-2007, 09:00 PM
badluck310 badluck310 is offline
So abject,.....
I'm wondering if you found a solution because im having the exact same problem. I just got my m-box mini and installed it and received the same error message. Except when i click ok the first time the second error message reads "The application failed to initialize properly(0x0000142. Click on OK to Terminate the application." So what do we do now?
Newbie [img]/images/graemlins/tongue.gif[/img]
Old 09-14-2007, 02:18 AM
bunderson bunderson is offline
You need the driver package located here.
http://www.paceap.com/dldrvr.html
Old 10-04-2010, 01:17 PM
do8 do8 is offline
I have the same problem as previously discussed.
So, I have the m-box mini, Pro Tools LE, which has worked perfectly in the past. I had to repair my computer a couple of weeks back, and a consequence of the repairment was that I had to get a new hard drive. Therefore, I wanted to install the software onto the new functioning hard drive to get working with my equipment.
I have installed the TKpd Driver as advised above.
Why does my software still not start?
Before I never had to use anything called Ilok, is that something needed to fully install the software a second time?
Updated TPkd driver required? soundproof VENUE Live Sound Systems 2 09-26-2007 04:00 AM
help (please) updated TPkd driver required liberccxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-26-2006 12:17 PM
Updated TPkd driver? eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2005 01:06 PM
Udated TPkd driver required PT7 Teolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-19-2005 01:14 PM
PLZ Help: Getting message Updated TPkd Driver rcrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2005 08:04 AM
