Old 03-26-2006, 02:29 PM
savanasdad savanasdad is offline
Default 60 cycle hum
I am trying to record an acapella song. I am getting a slight but audible 60 cycle hum that appears on playback, but is not audible as it is being recorded. Any suggestions?
Thank you
Tony
Powerbook 1.5 ghz, 1.5 gig ram
Lacie Extreme external drive
Digi 002 rack.
PT 7.0 LE
OSX 10.4.5
Lawson L47 and Shure KSM 44 through Vintech 1272
Also,Focusrite, Grace 101, Eureka pres and Digimax LT
Old 03-26-2006, 02:36 PM
Slim Shady Slim Shady is offline
Default Re: 60 cycle hum
So important you had to post it twice huh?
Just giving you a hard time, the DUC is often kinda slow, so a lot of people hit that 'submit' button twice wondering why the page hasn't refreshed yet.
Anyway, check your live room, maybe you have something humming in the room (lights maybe?). If you get several tracks with a tiny amount of hum on them and play them together, the hum will be a lot louder. You can test this by doing a recording with no mics plugged in, just record 'silence' for a while with all your mics unplugged. If the noise is still there on playback, then it's something with your rig, but if it's not there, it's something you're recording through your mics.
Old 03-26-2006, 03:08 PM
I'm an official member of the Department of Redundancy Department.
I had already done as you suggested and recorded silence. Hum still there.
I'm going through now and eliminating ground lift problems with each piece of gear. Still there.
I think I'm gonna eliminate some cheaper pres and use my better stuff directly into the 002. My Vintech hummed badly when patched in through the Digimax LT, but is as quiet as a mouse going directly into channel one of the 002. I suspect it's an issue with the Digimax. I'm gonna record silence using the Digimax pres and see if I still get the 60 cycle.
Thanks for your help.
Tony
Tony :smirk
Old 03-26-2006, 06:19 PM
oreo1 oreo1 is offline
I used to hum with digi 002 rack and a dual G5. I got an EBTech line level converter and that stopped it.
— Jim
Here's my latest CD: The New Old Time.
G4 Power Cycle zoggied General Discussion 8 10-14-2002 11:26 AM
Power cycle GS-DK Pro Tools TDM Systems (Mac) 3 01-24-2001 02:25 PM
Product Cycle??? Drew Mazurek General Discussion 1 11-03-2000 11:48 AM
60 cycle hum indieo General Discussion 3 10-04-2000 09:15 AM
Cycle playback... PeeTee Tips & Tricks 3 06-07-2000 11:06 PM
