#301
Re: MacOS Sonoma
Pro Tools Studio 2024.3 | Studio One Pro 6.6 | Logic Pro 10.8.1 | Dolby Atmos Render 5.2 & Album Assembler 1.3 | RME BabyFace Pro FS | UA Native Plugins & Sphere LX | SSL UC1 | 2023 Mac Studio M2 Max 12 Core CPU 38 Core GPU | MacOs 13.5.0 | Genelec 8020D & Yamaha MSP10 | Korg Kronos LS | Sonarworks Sound ID | Beyerdynamic DT 1990 Pro | DT 880 PRO | DT 770 Pro | etc. |
#302
Re: MacOS Sonoma
2020 M1 Mac mini Sonoma 14.2.1 here.
Ran a benchmark on PT-Studio 2024.3.0 and the results were embarrassing, to say the least. I've opened case with PT. See details below. Please let me know if you have a similar experience and or your thoughts on modifying the benchmark test to improve results etc. PT Case # 04773620 I'm currently benchmarking Pro Tools Ultimate 2024.3.0 against the Mac mini 2020 M1, on MAC OS Sonoma 14.2.1, running on interface UA Apollo x4. Note: Apple's latest version is 14.4. I've deferred the latest upgrade as there're compatibility issues between UA interface and third party plug-ins. MAC mini CPU usage before Pro Tools benchmark test Protools CPU usage = 23% - 30% The benchmark setup: 1 - Click track 1- Audio Group Folder Track 10 - Audio Tracks with audio clips 1-Instrument Group Folder Track 20 - Instrument Tracks with Xpand on the first insert on every track and UA SSL EQ E on tracks 1, 2 and 3 MAC mini CPU usage after Pro Tools benchmark test Protools CPU usage = 86% - 110% (steady) From Bar-1 to Bar-4 CPU usage hovers around 80 - 90% At Bar-5 and Up the CPU spikes to 110%. It remains there until you stop playback or you get a "Hardware exceeded memory usage, try changing your hardware setting if this continues" message. This behavior is reproducible even if you have your H/W setting set to the lowest sample rate of (32). According to how Apple defines it's CPU usage in the OS's native "Activity" app, "System": = ALL of the CPU resources required just for the OS to run "User": = CPU resources used by the logged in user's applications running "Idle": = Available CPU resource Given these definitions. I'm left scratching my head to understand why Pro Tools is identified as consuming over 100% of CPU resources, yet it's not reflected on the 'Activity" app System, User and Idle report? (located at the bottom of the Activity App) I've reached out to Apple about this. As there are other OS issues that surfaced when Pro Tools launches.Like, mouse jumping from one side of the screen and sporadically hopping around while scrolling. Their conclusion is that there's something weird going on with how Pro Tools is managing memory.
Dave, System Specs: Mac mini 2020 M1 Memory: 16G HD: 1T Mac OS: Sonoma 14.2.1 Interface: Apollo x4 Avid Product: Pro Tools Ultimate version 2024.3.0 |
#303
Re: MacOS Sonoma
Well I tried Sonoma 14.3.1 for my self today. After installing everything from scratch and after working with it for about an hour or so I began to run into so much bloat I almost thought I was on Windows. What have they done? Pro Tools 2024.3 ran really good on it but from my experience not as excellent as it runs on Ventura 13.5, which is where I have been for a long time. Like you guys said I didn't have any issue with any of my 203 plugins, many of which you guys have mentioned here in this thread. After working with it for a good while longer I decided to revert back to Ventura 13.5 which seems to be the sweet spot. I found no real advantage with Sonoma on the contrary I find Ventura 13.5 to be snappier and the Pro Tools CPU performance seems to be on par with 14.3.1. I guess if you have to buy a brand new Mac you will get by just fine but I will be staying on 13.5 as long as I can. I'm very happy with the overall stability and performance I am getting there. I would say to those who are still on Ventura, as of right now there's no real advantage in moving up to Sonoma for Pro Tools until necessary. It currently looks like I will be waiting for the next end of the cycle of Sonoma's replacement .This will be the first time I stayed two OS's behind. I will see what direction Apple is going in after that. If you are thinking about moving up, make sure you have a backup plan.
Pro Tools Studio 2024.3 | Studio One Pro 6.6 | Logic Pro 10.8.1 | Dolby Atmos Render 5.2 & Album Assembler 1.3 | RME BabyFace Pro FS | UA Native Plugins & Sphere LX | SSL UC1 | 2023 Mac Studio M2 Max 12 Core CPU 38 Core GPU | MacOs 13.5.0 | Genelec 8020D & Yamaha MSP10 | Korg Kronos LS | Sonarworks Sound ID | Beyerdynamic DT 1990 Pro | DT 880 PRO | DT 770 Pro | etc. Last edited by ZoeMusic; 03-23-2024 at 09:49 PM. |
#304
Re: MacOS Sonoma
It's an intel hackintosh, currently running 14.3.1 |
#305
Re: MacOS Sonoma
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD. 2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD. PT 2024.3 Native Life is like an Analogy. |
#306
Re: MacOS Sonoma
#307
Re: MacOS Sonoma
I have Mac Studio M1 Ultra - and would really like to have an easy to read list of things I can do to maximise the efficiency of the computer... I think the Avid one is a little out of date? Thanks guys...
Mac Studio M1 Ultra / 128G RAM / ProTools 2023 / SSL2+ / Furman PL-8CE /
#308
Re: MacOS Sonoma
For those who are still on Mac Intel, how is PT 2024.3 doing with Sonoma?
I'm still on Ventura and want to know if it's safe to upgrade. Thanks!
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
#309
Re: MacOS Sonoma
I built a bootable Ventura drive - did a “erase all contents and settings” - and reloaded *everything*.
I’m happy to report Pro Tools 2024.3 is working great on Ventura. I’ll wait a good long while before updating to Sonoma.
#310
Re: MacOS Sonoma
Glad you got it all sorted out!
macOS 12.4? | off the wall | macOS | 36 | 06-06-2022 11:50 AM |
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur | newstrings | Pro Tools HDX & HD Native Systems (Mac) | 6 | 01-15-2022 11:48 PM |
macOS 11.6.2? | off the wall | macOS | 9 | 12-19-2021 08:46 AM |
Macos big sur | nesseldigital | Pro Tools 2020 | 2 | 12-27-2020 04:49 PM |
6.0 and Macos X | gmcgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2003 09:08 AM |
