  #271
Old 03-12-2024, 07:51 PM
itsjustmeee123 itsjustmeee123 is offline
Default Re: MacOS Sonoma
Originally Posted by dominicperry View Post
Check your audio hardware too. Carbon isn't certified with Sonoma (with known problems), as an example.
Dominic
Thanks Dominic. I have a Presonus Quantum 4848 so all good there.
  #272
Old 03-17-2024, 07:10 PM
Fishbone Fishbone is offline
Originally Posted by JouluPam View Post
Hi all!
After upgrading to Pro Tools 2024.3 moving clips and fades around causes the transparency effects to flicker, along with the clips them selves. Very annoying. Anyone experiencing the same issue? Any help?
I'm on Sonoma 14.4. Didn't happen before 2024.3.
Thanks.
Yep, same bug here.
It's really annoying and make the important transparency feature practically useless.
MacMini M1 16Gb - MacOS 13.6.4 - 14.4 - Pro Tools 2024.3 - UAD Apollo Silver 8+16 - UAD Satellite octo - SSL UF8+UC1 - Softube Console 1 + Fader
  #273
Old 03-17-2024, 07:29 PM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
My system has become useless since 14.4 came out.
I'm so frustrated with how brittle this app & ecosystem are. Is it AVID? Is it PACE? Does it matter?
Yes yes I know - I should freeze a working system in Amber until some vaguely defined tipping-point is reached then back everything up (again), install the updates on an external etc etc.
It's 2024 - this level of fragility is ridiculous.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #274
Old 03-18-2024, 04:35 AM
thin ice thin ice is offline
From what I ready, this is an iLok problem affecting more than just Pro Tools users. What we wouldn't normally expect is an incremental OS update with security patches to break everything.
Does temporarily setting your DAW and the iLok License Manager application to run in Rosetta mode fix the issue?
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
  #275
Old 03-18-2024, 07:03 AM
BCnSTL's Avatar
Running in Rosetta does not change anything.
Some sessions will playback for a 1 - 2 bars then hang, some won't open at all, some very basic sessions will play.
The *only* thing that has changed is the 14.4 update.
I get it - if you depend on a stable system for your livelihood then freeze it in amber and update only when you have time and backups ready etc.
I need my computer for other things and when I steal precious time to work on music it is so deflating to be denied.
PT 2024.3 Native
  #276
Old 03-18-2024, 07:16 AM
JFreak JFreak is online now
Oracle is reporting that 14.4 broke JAVA, so i would not be surprised if it also breaks PT. Apparently they have done some very low level changes lately.
  #277
Old 03-18-2024, 07:29 AM
Did you run iLok License app in Rosetta too, as this is reported as working on the Universal Audio site.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
  #278
Old 03-18-2024, 12:48 PM
BCnSTL's Avatar
Ah. That I did not do.
Do you mean run the iLok app in Rosetta while running PT (in Rosetta as well)?
How does one run "Pace" in Rosetta?
PT 2024.3 Native
  #279
Old 03-18-2024, 01:22 PM
- Quit all music-related applications such as your DAW and iLok License Manager.
- Navigate to the Applications folder and find your iLok License Manager application.
- Right-click (or Control + Click) the applications and choose Get Info.
- In the Info window that opens, look for the Open using Rosetta option and enable it.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
  #280
Old 03-18-2024, 01:55 PM
After doing this you need to restart the machine, or the login items won't get started under Rosetta.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
macOS 12.4? off the wall macOS 36 06-06-2022 11:50 AM
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur newstrings Pro Tools HDX & HD Native Systems (Mac) 6 01-15-2022 11:48 PM
macOS 11.6.2? off the wall macOS 9 12-19-2021 08:46 AM
Macos big sur nesseldigital Pro Tools 2020 2 12-27-2020 04:49 PM
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
