  #71
Old 03-08-2024, 09:50 AM
RobertDorn RobertDorn is offline
Default Re: PT 2024.3 | Released
Originally Posted by koka View Post
Nice!
Did Avid fixed HD driver for Intel Macs?
I have Bad issues with New HD driver versions on Intel Mac.
Read the knowledge base. Intel Mac (pro) should use HD driver 2023.3
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
  #72
Old 03-08-2024, 10:00 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Originally Posted by MLaudio View Post
Working great here.. Really nice being able to use Reasons player devices directly on the Instrument track. Glad to see PT getting some midi love.
Wait, you can do what now? I love the Reason player devices - please explain/expand!
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #73
Old 03-08-2024, 10:02 AM
Peter Sprague Peter Sprague is offline
For this release they say it runs on Sonoma 14.3. When I go to upgrade my Mac OS I can only choose to update it to Sonoma 14.4.
What did you folks do?
thanks for your help, Peter
  #74
Old 03-08-2024, 10:07 AM
mwongsound mwongsound is offline
Yeah the irony of it all! The day Protools releases a version compatible with Sonoma 14.3.1 is the SAME day Apple STOPS signing 14.3.1 and pushes 14.4 with no way to upgrade to 14.3.1. (I'm guessing due to some sort of security exploit)
Ive seen some individual full blown installers for 14.3.1 from dubious sites but no combo update installers. Hopefully someone has an answer.
Ive also seen an alert about Pace security incompatibility with Sonoma 14.4.
Patience is a virtue, maybe wait another 6 months for 14.4 to become Protools 'approved'
  #75
cqd cqd is offline
So does any plugin with a midi out just work as you'd like it to?..
  #76
Old 03-08-2024, 10:16 AM
Eric Lambert's Avatar
Originally Posted by Halfmoon View Post
WRT EUCON - Try going to EuControl Settings > Applications, removing PT 22.3 (or whichever previous version might be listed there) and then add in PT 24.3 (make sure you have it launched and have clicked/focused it right before going back to EuCSettings>Applications).
Hopefully that'll slap it upside. Worked here for me.
M
Turns out there was some app running (related to plugin scanning) in my dock which had prompted a question. I clicked the answer, it went away, and suddenly all EuCon devices popped right up. Strange.
  #77
Old 03-08-2024, 10:19 AM
Originally Posted by BScout View Post
You've probably not re-added Pro Tools to the application white-list in Eucontrol.
This Pro Tools identifies differently than last year's as 24Mac (verses all versions last year as 23Mac.) So it gets ignored.
That's why you don't have Eucon (it's working fine here)
I swapped that out right away -- it was (or appears to have been) that orphaned app scanning for plugins which was holding it back.
  #78
Old 03-08-2024, 10:45 AM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Originally Posted by edrawl View Post
Regarding MacOS Sonoma, Apple just released 14.4 yesterday. Is that compatible with PT 2024.3?
Currently the officially supported Sonoma version is 14.3.1.
https://avidtech.my.salesforce-sites...tibility-Chart
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
  #79
Old 03-08-2024, 10:58 AM
Tweakhead Tweakhead is offline
Direct download Sonoma 14.3.1 from Apple via Terminal command:
softwareupdate --fetch-full-installer --full-installer-version 14.3.1
then Use Terminal to create the bootable installer (obviously replace the word Ventura with Sonoma):
https://support.apple.com/en-us/101578
  #80
Old 03-08-2024, 11:09 AM
blackmacdaddy blackmacdaddy is offline
Great! I'm fetching the 14.3.1 Sonoma installer right now via terminal via Tweakhead's info.
Where will I find it when it finishes?
Currently at 4% "installed" (terminal's syntax there)
Thanks to any and all replies. :)
It's only R'n'R but I like it.
What I would like to see in ProTools in 2024 ! stevegalante Pro Tools 125 03-25-2024 12:37 AM
Runnind PT 10 and 003 Factory with NEW 2024 Mac PRSWILL macOS 20 01-18-2024 07:08 AM
