Eucon Software doesn't recognise Artist Control
I've changed my Mac from 2013 Mac Pro to M2 Mac Studio. I can no longer use my Artist Control with the new Mac Studio. The Eucon control software doesn't recognise it. I use Mac OS Ventura, Pro Tools 2023.6 and Eucon 2023.6. I have already changed the hostname of the Mac Studio. I also use an Avid Carbon plugged into the ethernet port. So, I use an adapter (TB to Ethernet) for the Artist Control. However, I tried also to plug it directly into the ethernet port with the carbon discarded. Same problem. Can anybody help?
Re: Eucon Software doesn't recognise Artist Control
Make sure the versions are the same for AC and EuControl What IP addresses are the tablet and the Ethernet adapter? |
Hi Eddie,
Thanks for your answer, but you misunderstood me. I'm not talking about Avid Control, I'm talking about the Faderbox Artist Control: https://www.gear4music.be/de/Keyboar...ontrol-v2/17BI It's not recognised anymore. |
I guess your problem is this device is obsolete and not supported by newer versions of EU Control.
Best, Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
I understand this page like this: The software still works but the device is no longer sold and there are no more spare parts.
Or does the current Econ software no longer work with the Artist series? https://www.avid.com/de/resource-cen...ntrol-surfaces |
You understand correctly.
The Artist Series still works with the current version of Eucontrol. If it isn’t showing up as a possible surface, there is some other issue. Did you set up the Artist controller with a static IP? Reset the unit to use dhcp.
I found it 😊.
I had to change the network connection in the Apple System Preferences. There is an extra tab for Eucon. There you can select your network connection and I had to change it from USB to Thunderbolt. Thanks for your help anyway. |
PT 2021.10 No Go on Mac 5,1 with Eucon & Artist control | TommyT | Pro Tools | 13 | 11-01-2021 01:55 PM |
Eucon 3 - Artist Control not connecting to PT | Trazan | Artist Series | 50 | 04-04-2016 03:14 AM |
ATTN JC. Eucon 2.7 + Artist Mix/Control via HUI | Herbieoz | Artist Series | 5 | 01-09-2015 02:14 AM |
Eucon, Artist Control and mouse. | vinnyburns | Artist Series | 6 | 04-16-2014 06:43 PM |
Artist Control not working with Eucon 3 on OS X 10.8.4 | Jerry Woolsey | Artist Series | 1 | 06-24-2013 01:21 AM |
