pts file doesn\'t work when transferred
my bandmate and i both have pro tools le 5.3.1 on windows xp. whenever we record something on one computer and transfer it to another the pts file gets messed up. it either doesn't show the wav files or lines them all up at the beginning of the track.
we transfer all the wav file along with the pts files and put them in a new 'audio files' folder. what are we doing wrong?? *dv* |
Re: pts file doesn\'t work when transferred
Being a fairly new user myself, I could only offer you a hint ; "PT project files ( *.pts ) don't reside inside an audio folder. Rather... they both, along with the fade files live inside the master " session " folder side by side. Makes sense ??? cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
To transfer a session.. create a localized copy using Save Session Copy In... in the File menu.. and check to copy the audio files. You can then burn this copy to CD, DVD or copy in Explorer to another drive.
If you're importing tracks between sessions, then make sure your session start times are the same.. or allow for that in the Import Track Data dialog. Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
thanks, we'll try this out!
*dv* |
Transferred Plugs | shareec70 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-14-2009 01:44 PM |
Transferred files between 5.1.1- 5.3.1,gives error | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-21-2003 02:15 PM |
PT not recognizing files transferred from PC | nodell | Pro Tools TDM Systems (Mac) | 3 | 05-01-2003 05:22 PM |
Help...anyone who has transferred from DAT to MBox | MarcB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-16-2002 06:52 AM |
low levels on transferred tracks | 372cat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-28-2002 02:48 AM |
