Most stable PT version for HD2 on 8 core XP?
After more than 10 years running protools mixplus and HD2 smoothly on non-recommended PCs, I finally bought a recommended Dell T7400 and put 2 quad core 3.2GHz Xeons in it, with 4GB and XP. It's a nightmare, as soon as I get near 1.5GB memory use for PT (with PT8 cs3), it crashes to BIOS reboot. I have tested all the memory - this PC has no problems I can detect.
I can't find anyway to stop it caching plugins after unloading them, so I have to close it all down after deactivating some tracks just to recover the memory Trying to get value out of these 8 cores seems impossible, since I cannot get past 50% CPU before memory blows it up, unless I set up 300 Dverbs or dozens of Elevens. Also it sometimes says it has RTAS errors when it's loading the CPUs less than 10% - this a machine with 8 cores and a 1600MHz bus. It's not much more stable than when I tried it with windows 7. I fancied trying an 8 core Mac, but it is way too pricey since I'd need to move to PCI-e cards. I'm using NI Komplete, Kore 2, arturia, IK stuff, Korg, BFD, KitCore, velvet, etc + loads of digi plugins. Kore & kontakt hog the most memory. Rarely can I get more than 5 RTAS instruments active at the same time should I go back to PT7.x ??? or is 8.0.1 worth trying? Or should I just grit my teeth until 64bit arrives?? Anyone know if the Track "freeze" facility is coming? Cheers Tony |
Re: Most stable PT version for HD2 on 8 core XP?
Go back to 7.4.PT8 is most likely your problem.
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
Most stable PT 9 and OSX 10.6 version? | allen_gibberish | macOS | 6 | 11-06-2011 04:07 PM |
Most stable OS version | OddsAre | macOS | 3 | 02-01-2011 11:44 AM |
Which PT 8 version is currently most stable? | smpkeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-18-2010 05:15 PM |
The most stable version of PT | sphereman | Pro Tools TDM Systems (Mac) | 53 | 02-24-2007 12:01 PM |
Is the PT .5.0 stable version? | JACEK GAWLOWSKI | Pro Tools TDM Systems (Mac) | 11 | 01-19-2000 12:55 AM |
