Ultimate Soundbank Plug-ins help!
Does anyone have any experience working with the Ultimate Soundbank Plugsound series please? I have just bought Volume 5 which is for synths and followed all the instructions for installation, yet the plug-in does show up in my PTLE 6.4 list of plug-ins.
I have copied the .dat and .dll files into the plug-ins directory via windows explorer and installed the PS05 windows installer and no show. I have tried contacting the plug-in manufacturere's technical support but nothing is forthcoming so I thought I should ask here in the meantime to see if anyone has experienced this problem. |
Re: Ultimate Soundbank Plug-ins help!
Plugsound is only very recently Protools Windows compatible. Go Here to find the RTAS updates.
The files you moved are VST files and Not RTAS. To work in Protools, you will need to install the RTAS versions which will then be seen by Protools.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Ah, that would explain it. I wondered why the instructions said copy those files to your vst plug-in directory. Although I just copied to the DAE/plug-ins direcctory, assuming it was the same thing. Problem with their support is that you have no access to important files/information until you have registered and you can not regsiter until you access the program. Meanwhile I have emailed them but no response. There does not appear to be anywhere I can get the rtas equivalent of those files. The instructions are virtually non-existent.I hope they respond with how I can get the rtas files you refer to.
Thanks by the way. |
I already installed that, still the same problem. I suspect the problem may be with the files I copied from the cdrom which may be vst and not rtas
the RTAS files have the extension .dpm and .dpm.rsr
There is a .dpm file but no .dpm.rsr
It seems that could be the problem. Cos when I look in explorer, there are many files which have both .dpm and .dpm.rsr extensions |
Copy all .dpm files into Prohgram Files- Common Files - Digidesign - DAE - Plugins. You may be OK that way. Every plug-in company has a slightly different take on their format. The one consistent is the .dpm file.
The files are all in the exact location you mentioned
Have you tried inserting on a stereo track? Some modules are stereo only, others are mono only.
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 04:44 AM |
Moving Presets to another Soundbank in Mach Five | ej | Tips & Tricks | 1 | 08-18-2005 06:07 PM |
the ultimate plug-in collection - LOL | Alécio Costa | Pro Tools TDM Systems (Mac) | 4 | 06-01-2005 09:17 PM |
Online SoundBank | transology | Tips & Tricks | 1 | 05-19-2004 11:54 PM |
Strange error when installing Reason Soundbank | Voideco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-01-2001 02:21 PM |
