buying a new mac
I've been wrestling with my PC and my 002R and I'm thinking maybe I should just buy a Mac and be done with it. Can I just order a machine from Apple or are there a bunch of hardware caveats like with a Windows machine? Will I need to buy any additional hardware? I was looking at a 2Ghz dual processor G5 with 2G of RAM. Is a stock HD from them going to be OK for the operating system? What about the audio drive? Thanks for your help!
Re: buying a new mac
The G5 will work wonderfully right out of the box. Just add a second HD for audio like a WD Raptor drive and then you are all set.
- Jason |
...and max it out with RAM.
Gordon in Austin Mac G4 Digital Audio 466MHz MacOS 9.2, 1.25GB RAM, 110GB HD digi 001, PT LE 5.3 |
Is 2G of RAM plenty? The price of the Mac really starts escalating beyond 2G. Would more RAM be better than the second processor? Thanks for the input!
You dont need to max out the ram/not for Protools anyways!2 gig is more than enough!The second drive is the one thing you must have though, & seeing as the G5 supports SATA drives, your laughin!
If you decide to go Mac, check out Smalldog.com. They sell refurbished and new machines and have very excellent service. They even sell some pro audio software and hardware. If you want to buy a new Mac from them, you just have to buy something -- anything, even just a little widget -- from them to qualify to buy their new machines (this is a caveat of their deal with Apple.)
I've bought two refurbished machines from them and not had a lick of trouble -- plus their customer service department actually understands customer service. Good luck... |
Excellent! Thanks everyone!!
I just bought my G5. What can I expect as far as converting my WinXP tracks on the current firewire drive? Im hearing mixed messages re: reconfiguring the drive and the old data working out of the box.
Any help is much appreciated? |
Which Sata drive do you recommend and what size are you using? I presume no PCI card is needed to make this work? Thanks Hotso Quote:
I got two 200G SATA drives on Ebay (new ones) from one of those guys with an outlet store. They were under $100 each and say Maxtor on them. That'd mean they're Maxtors, huh?
I know I've mentioned this before, but OSX will configure the two internal drives in a raid scheme. I run my system and PTLE on an external FW drive and I record to the two SATA drives. Neither Digi nor Apple say you can do this, BTW. I do. Yer gonna laugh when you get to install the drive inside the computer. It could conceivably take you more than 60 seconds, but not much more. No PCI card needed.
664 The Neighbor of the Beast |
Buying a used Mac Pro. | Drew Mazurek | Pro Tools TDM Systems (Mac) | 13 | 03-09-2011 11:06 AM |
buying a PT 7 PC UK | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-04-2006 05:52 AM |
Buying | A. Simon | General Discussion | 2 | 09-29-2003 07:37 PM |
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-18-2003 11:53 AM |
Buying Mix 24: Which CPU should I buy? | Chris Tveitbakk | Pro Tools TDM Systems (Mac) | 6 | 11-01-2002 03:09 AM |
