Error Message on PT8 HD Upgrade
So i just wiped my system clean, installed snow leopard, installed PTHD8. I'm getting an error message on start up while creating core audio objects. The error message is DAE Error -1127. Can not find much info in this. Any ideas? I've deleted all prefs etc and uninstalled reinstalled several times and still get the message.
HELP!!!!! Thanks, DL |
Re: Error Message on PT8 HD Upgrade
I think you're likely looking at a hardware issue!! If you have process cards or accel cards installed then check the flex cable that connects them to the core card. check that the flex cable is going from port "B" on the core card to port "A" on the first connected card, and the same from then on... port B to port A on the next card etc. it can seem logical to go from port A to port B but that is wrong it must go from port B on the core card to port A on the first process/accel card and so on. Also check all other connections to the cards and re-seat the cards in the PCI slots to make sure they are seated right down etc. Chris
Does anyone know what this error message means. ERROR DAE 9060 | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-18-2009 11:41 AM |
A Message But Not An Error Message | RichrdC | Pro Tools M-Powered (Win) | 3 | 01-27-2008 06:57 PM |
Problem 7.4 Upgrade Error Message - Record Volume | akakpaws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2007 08:45 PM |
After 6.4 upgrade this message comes up ??? | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-10-2005 03:58 AM |
6.1 upgrade error message when trying to run PT | Adrian D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-30-2003 05:42 PM |
