Old 12-23-2016, 05:38 PM
440Hz's Avatar
440Hz 440Hz is offline
Default Re: Bug?: Import Session Data Window Too Big
Originally Posted by mu-tron-kid View Post
On a standard MacBook Pro, Pro Tools 12.5.2 has a similar issue where the "MATCH TRACKS" section gets squeezed to only allow seeing one or two track names at a time. The Scroll buttons are basically as big as the sliver of space allotted for the tracks.
Why can't we have resizable sections, as I definitely prioritize the bottom two areas over any of the initial info in the top 2 sections...
Since repeat visits retain the "previous" values for TimeCode, Import Options, etc. why not make the only area that requires a selection the largest space hog?
I am having a similar issue except in the MATCH TRACKS section I cant see ANY of the session tracks???
440Hz
Yarra Valley, Melbourne, Australia
Mac Pro 2,1 Dual Quad Core 3GHz 18 GB RAM
OSX 10.9 Maverick's
3 x 1TB SATA 1 x 250 GB SATA (Seagate)
PT 12.6.1 HD
MC MIX
RME UFX, Ferrofish A16 AE
MIDAS Venice 320
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side." Hunter S. Thompson
Old 03-25-2017, 09:20 PM
440Hz's Avatar
Anyone...?
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 03-25-2017, 09:36 PM
mu-tron-kid mu-tron-kid is offline
Location: Ithaca College School Of Music, Theatre, and Dance
Default Bug?: Import Session Data Window Too Big
If your OS supports "Double Click on Title Bar...", this will maximize the Import Session Data window and enlarge the Match Tracks area.
Usually this also moves the "OK" button below the screen edge, so you need to double click the top bar again when done to Cancel or "OK".
Brian Dozoretz
ACSR
ACI Dolby Atmos
Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink,
Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4
VENUE SC48 3.2 with iPad Control
SSL Duality
SSL Duality via ipMIDI / ∂elta Automation Plug-In
Old 03-25-2017, 09:55 PM
440Hz's Avatar
Thanks very much for your reply !
Where would I find "Double Click On The Title Bar Option'?
I tried to double click on the Import Session Data Window title bar but nothing seemed to happen.
Cheers
Nic
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 03-25-2017, 10:00 PM
Mac OS El Capitan and Sierra:
https://support.apple.com/kb/PH21915...ewlocale=en_US
Brian Dozoretz
ACSR
ACI Dolby Atmos
SSL Duality
Old 03-25-2017, 10:02 PM
http://www.cultofmac.com/410346/how-...g-full-screen/
Brian Dozoretz
ACSR
ACI Dolby Atmos
SSL Duality
Old 03-25-2017, 10:36 PM
440Hz's Avatar
Hey Brian,
Thanks a bunch for the links.
I've found a workaround thats pretty annoying but workable.
The double click thing doesn't seem to work as it seems to make the Import Session Data window so large that I can't access the 'DONE/Cancel' button at the bottom of the window as it's disappeared off the bottom of my screen.
If I temporarily change the screen resolution in system prefs I can view the session data window, make my selections, then change the resolution back... total PITA
440Hz
OSX 10.9 Maverick's
PT 12.6.1 HD
MC MIX
MIDAS Venice 320
Old 01-23-2019, 08:29 AM
GaryWarth GaryWarth is offline
I had the same problem with Pro Tools 12 in Windows 7. Changing the resolution did not help, but I found a solution by changing the orientation from landscape to portrait, which flipped the screen on its side, making it long enough to fit the window I had opened. It was awkward to work the mouse, but once I completed the settings on the window, I closed it, set it back to landscape, and everything worked.
match track in Import session data window issue dgoodi22 macOS 5 09-06-2013 12:35 PM
Import Session Data window scroll Vedat macOS 0 07-31-2012 06:28 PM
10.1.1 Import Session data window size bug? meech macOS 0 03-27-2012 09:25 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
FR: resizable import session data window travista00 Pro Tools TDM Systems (Mac) 5 09-01-2009 05:58 AM
