Command|8 (Offline)
I just got a Command 8, and am really frustrated. I'm using a 24" iMac with OsX 10.4.8 running ProTools LE 7.3. The Command 8 is connected to the iMac with a USB cable. Its firmware is 02.01.02. I can't get it to stop saying "Command|8 (Offline)" except when I hit the "Stand Alone" or "F1.Utility" buttons. What am I missing? Please help!
Re: Command|8 (Offline)
You also need to tell ProTools it's there: it won't automatically recognize the control surface just because it's plugged in. I haven't done it in a while, so I may not remember the steps correctly... so look in your manual for the right way to be sure. Look for the "Peripherals" set-up somewhere in ProTools, and there'll be a section (second from the right, I believe, can't remember what it's called) where you'll be able to tell a) ProTools where the commands are coming from and b) where to send replies to (so your control surface reflects fader positions, pans, etc. once they've been changed).
That's your problem.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
power up c8 launch pro tools choose setups then peripherals open midi controllers,choose c8 from the pop-up menu,that should do it.good luck
This is seriously frustrating. My command 8 was working when i first plugged it in. Protools crashed (i had the PT7.x unable to type text error) and since then my C|8 has been offline. Its ports are not visible in the Midi Controllers menu, so i cannot choose it. I've deleted preferences, still to no avail.
The only love i received is when i ran the C|8 firmware updater, which re-enable me to use it, at least until PT crashed again. Now my command 8 is offline again and my Firmware updater cannot locate the command 8. I've changed USB cables, changed USB ports (i know it sets itself to a particular port, so i've gone back to the original one). Digi, this is retarded. How the hell do i get PT to see my command 8? fman PT7.2 HD, Quad G5, 4.5GB ram, using C|8 via USB. |
hi.open pro tools go to set up choose peripherals choose midi controllers choose command8.that should do it.good luck.it worked for me.
Command 8 Offline FIX | TDub | ProControl, Control|24, Command|8 | 2 | 11-20-2011 01:59 AM |
D-Command Offline | jim2step | ICON & C|24 | 3 | 04-27-2010 09:52 AM |
Yet Another Command 8 Offline | idoteech | ProControl, Control|24, Command|8 | 1 | 10-25-2008 05:16 PM |
command 8 REALLY OFFLINE | frewno | ProControl, Control|24, Command|8 | 0 | 10-31-2006 08:23 AM |
Command|8 Going Offline | Chief Technician | ProControl, Control|24, Command|8 | 19 | 08-16-2005 05:58 PM |
