Just a quickie.... SPDIF and digital noise
So I set up my laptop with my M-box to get a feed from a DAT recorder via the SPDIF inputs. Getting the audio was fine and I recorded the gig. Unfortunately i wasn't monitoring the audio... this was a back up test.
On playback the audio has come out with digital noise that rises and goes with the audio level. Also, the file is maybe slightly slower than what it actually was. Possible answers... 1)The DAT was set at 48KHz and the Protools sessions at 44.1Khz...??? PT was select to internal clock source???? 2)The cable was not co axial... just a thin RCA.? 3) The M-box SPDIF input is bad/The DAT SPDIF output is bad. I did convert the audio into a 48Khz session but the noise was still there. What could it be and can I fix it... Thanks JJ |
Re: Just a quickie.... SPDIF and digital noise
what can you do? re-transfer it.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
First: you need to tell both systems to sync off the same clock. So... You can put a second SPDIF cable between the Protools rig so that you have a feed FROM protools to clock the DAT to, as you transfer FROM the DAT to Protools on the other cable. OR, you can tell protools to clock off the DAT. Regardless, you will also need to assure the protools session is set to match the dat recording session.
Second: the RCA cable is fine... it's just 1's and 0's. cheers geo
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
Fast Track Ultra spdif - digital noise only | wallykissel | General Discussion | 3 | 03-04-2013 01:16 PM |
Digi 002 SPDIF / Art Digital MPA - Need help! | scava | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-02-2010 01:30 PM |
Digital Clicks using SPDIF | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-18-2008 12:10 PM |
SPDIF digital input | Electrohermit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-25-2003 07:43 PM |
SPDIF OUT gives digital cracks | Rob van Hees | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-19-2001 07:17 AM |
