#51
Re: Pro Tools cannot find (all) my aax plugins.
The big things is make sure your audio/ session file are on a separate HDD ... and make sure I have multiple backups specially of the audio/session drive. And if/when you want to increase performance more in future you have M.2 NVMe drives as an option to consider. |
#52
Hi Darryl. Thank you so much.
I am now trying to transfer my session file from the hard drive in the Mac to an extern hard drive formatted exFAT. When I copi or draw a little window saying : subject " System volume information" can not be replaced, because it is invisible. Are you able to guide me from here ? |
#53
Hi Darryl. I think that the issue with : subject " System volume information" can not be replaced, because it is invisible, maybe can be related to that the Mac ssd system hard drive is overcrowded. The strange thing ( for me ) is that the info on the mac say that the ssd hard drive is full. When I go to users -it shows shared 29 GB. On the logo with the house ( Jesper Thorup) the info shows 416 GB. When I take all the subjects / folders ( fotos film programs etc.) inside this and add them, theres is only 224mb ??
Do you have a solution to what I can do to solve the issue with transferring my sessions hard drive to my external hard drive from the Mac to the PC, as I have done without problems before. Thank you Jesper As you know I have |
#54
If you are trying to correctly drag and drop all all the session folders--then what is likely happening is there is a conflict with .VolumeIcon.icns or similar special hidden files (hidden files start with a ".") that the Mac is not happy about overwriting. The Mac is trying to be safe and user friendly and actually being unfriendly, like only Apple can do. What I would do is this https://apple.stackexchange.com/ques...it-s-invisible (actually that's one of the first setup things I do on any Mac, so I'd never exactly see this error). This won't harm your Mac but it will make different hidden files show up in the Finder, be careful not to delete those files. So then try again if you see an error about overwriting a file like .VolumeIcon.icns just say yes and keep going. If you see a bunch of different file names note them down and let me know... but keep going you are not hurting anything on the Mac as long as you drag and drop from the Mac to the exFAT partition. |
#55
Hi Darryl.
I am now dragging the sessions folders from the mac hard drive one by one to the external hard drive. It seems to work fine .... except one folder " System Volume Information" which you can't drag because it's invisible. So my question is " do I need to drag it, or can I just replace it ( from somewhere?) on the PC |
#56
#57
Hi Unkje.
Thank you for refering to Darryl who has been a great help to get my Mac hard drive transferred to my PC. I have a friend trying to help me to make Pro Tools work with Velvet( Avid) and Structure ( Avid). He is trying to explain "where we are" I attach some screen shoots. I hope you can help me thank you Jesper The folder structure is as outlined by unkJE. XPand2, Velvet ands Structure were all installed. The content for all three plugins is in the respective folders in G:\AIR Music Technology\Air Content\ Xpand2 is available in the instruments list, but Velvet and Structure are not. (See picture) The Xpand2 AAX-plugin is in C:\Program Files\Common Files\Avid\Audio\Plug-ins. The Structure and Velvet plugins seems to have the extension DPM and not AAX. They are in another folder. (See picture) Is DPM an older 32-bit plugin type? Can ProTools 12 use this plugin? Why is it not availablein the list? |
#58
Hi Darryl
I have now transferred my sessions hard drive from the Mac to my PC. THANK YOU so much for your help (-: If you have any comment to the thread I just send to Unkje about The issue with Velvet and Structure please tell me. best Jesper |
#59
here is the two attached files
#60
??? What are you folks doing now? Are you running the latest compatible Windows installers for the plugins? dpm are RTAS plugins, ideally they would not be installed but some installers will still just drop them onto modern systems.
In general: 1. Installers may give you a choice where to put sample libraries 2. The plugin may come with setup software that makes it easy to move libraries or point to them after you moved them (so let the install go to the default location) 3. The plugin documentation will describe how to do this (plugin installer manual, user manual or website) This stuff you should be about to find online. But all this needs to start with you running the correct Windows installers. Are you doing that? |
pro tools first can't find plugins | majselbaum | Pro Tools | Intro Discussion | 2 | 06-03-2017 07:17 AM |
Fresh install of pro tools anyway to find 3rd party plugins | Raoul23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-21-2010 03:46 PM |
Can't Find Plugins. Help, Please!! | lclebsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-05-2010 12:24 AM |
Can't Find Plugins | Newkid1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-30-2009 05:31 AM |
Pro Tools doesn´t find plugins:( (iZotope). | Vill! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-19-2008 06:07 AM |
