Old 11-24-2013, 05:37 AM
benherron.rrr benherron.rrr is offline
Default Audio playback problems
I've recently started to transition over from Pro Tools 10 to 11 now that all of my VI's have AAX64 support. I have found that PT11 has no audio playback, when I load an instrument or open a previous PT10 session all loads as it should and I get feedback from the channel meters, yet no sound. If I close PT11 and open the same project in 10 I have full playback. I also have a similar problem with my MIDI Keyboard (Studiologic Numa Nero), in that when I open PT11 the keyboard seems to make no connection, yet in 10 it works perfectly.
I am running an Mbox 3 Pro (All drivers up to date), PT 11.0.2 and PT 10.3.6 on a windows 7 pro machine. I have made sure the routing in Pro Tools is as it should be, have made all the recommended optimizations but I am a bit stuck now.
Old 11-24-2013, 09:30 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Audio playback problems
Have you checked in setup to make sure your interface is there and selected?
Also, have you downloaded both drivers for ten and eleven?
Disk
Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
protools@verizon.net
Live and Let Live
Old 11-24-2013, 11:09 AM
Disk
Ah, sorry, should of mentioned that. Yeah, the interface is showing and selected (its the only audio device I have installed) and Yes I have downloaded both drivers but I may go back and check this again.
Old 11-24-2013, 11:34 AM
Also my Keyboard shows up and is selected in the MIDI devices list in PT11, yet is unresponsive. I have had both the audio and MIDI working previously
Old 11-24-2013, 05:53 PM
Look and see if the track outputs are showing in dark grey and italics(indicating non-working outputs). Also, make sure Input Only monitoring is not selected(Alt-K toggles this feature and it shows as ON by a green square to the right of the transport along the top of the EDIT window).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 11-25-2013, 12:49 AM
mhmh mhmh is offline
Same applies to the I/O Setup, that's what happens to me all the time. Check the bus-tab of the I/O Setup for italics on the right side.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 11-26-2013, 03:51 AM
Thanks for your replies, I had already checked to make sure that all of my I/O were active, which they were. Admitedly, my MIDI keyboard problem was sorted with the MIDI Thru option. I found a strange solution for my lack of audio, I tried changing the H/W buffer from 256 to 1024 and then back to 256 this made the audio playback work, but I have to do this every time I open PT11.
Old 11-26-2013, 05:02 AM
guatamas guatamas is offline
Disable your mbox as the default playback device (control panel/hardware and sound/sound) when you want to use PT 11. At the moment this is an issue for us mbox pro users on windows along with the other issue of not being able to select different sample rates or getting a "unsupported sample rate" error message when creating a new session or opening a previously created one
Audio Playback Problems...Please Help!!! cedz636 macOS 15 09-09-2013 03:31 PM
Audio Playback Problems - Various CPG Pro Tools SE and Essential (Win) 0 11-08-2011 04:20 AM
Problems getting audio playback other than PT sgmarshall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-06-2006 09:18 AM
hd2 logic pro 7.1 audio playback problems quincygriffin Pro Tools TDM Systems (Mac) 3 01-06-2006 12:27 PM
AUDIO PLAYBACK PROBLEMS 139318 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-12-2000 12:56 AM
