Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 08-31-2009, 08:06 PM
jba jba is offline
Default DigiDelivery LT will not power on (8/31/09)
My DigiDelivery has been reliable since I got it in 2004. I don't use it very often. So, 99% of the time it is powered off. The last time I used it was in March of this year and everything was fine. I powered off via the software as is always the case.
However, I went to turn it on today and nothing happened. I pushed the power button on the front of the unit and nothing. The #1 USB light was flashing intermittently (as it always does to show a connection) but nothing with the power button. I tried securing the power plug into the back of the unit and tried several wall sockets as well with no luck.
Any suggestions?
Thanks for the assistance!
Old 08-31-2009, 11:22 PM
jba jba is offline
Default Re: DigiDelivery LT will not power on (8/31/09)
As a follow up....
I removed the top cover to look and see if there was a blown fuse. While, I didn't find a fuse, I did re-seat the 3V battery. Then, suddenly, when I plugged the unit back in, it started!! However, after a few inits scrolled by on the display window, it gave the following message:
BIOS Post: 7F
Msg: Disp Error
Does this mean replacing the 3V battery will fix the issue?
Thanks!
Old 09-03-2009, 02:35 PM
Pythagor Pythagor is offline
not really
try to connect monitor and keyboard and see what messages you get
Digidelivery!!! TAFF Post - Surround - Video 6 12-02-2010 07:26 PM
Digidelivery!!! TAFF Aspera DigiDelivery 1 12-01-2010 11:56 PM
DigiDelivery ? mushmouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-14-2006 11:11 AM
DigiDelivery ? mushmouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-13-2006 11:50 AM
Digidelivery oilbedamned Pro Tools TDM Systems (Mac) 14 04-25-2006 09:21 PM
