No Video Frames?????
Can't import movie (quicktime dv/dvcpro - ntsc) into pro tools. the system says... could not import, because there's no video frames?
im on LE 7.4 with a mac. any help? i need to start working on this picture. mike
NuanceTone.com |
Re: No Video Frames?????
What is the exact name of the QuickTime file?
I had this problem once, a while ago on LE 7.1. It appeared that the video was an MPEG2. I just converted it to DV using MPEG Streamclip and that worked... So maybe that will work for you too. Philippe |
ok so here's the actual file name
DV, 720 x 480 (640 x 480), Millions it's also in 23.98? thinking that might be the issue. if i convert the video using QT pro, to 29.97, won't it all be off in layback? and the file name is .mov data rate = 23.02 mbits/s source = /Volumes/itunes : Video/Video/Ben Nurick/Psychic Intervention.mov any help?
NuanceTone.com |
ProTools gives this error when the Quicktime movie file name has slashes in it.
There may be other conditions or characters that cause the error too... I just discovered this the other day myself - it cost me a half hour figuring it out. -jeremiah |
See here
No video frames |
Video Capture aborted due to doppes frames | abx992000 | Pro Tools TDM Systems (Win) | 0 | 06-02-2011 12:20 PM |
Video frames not advancing | machew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-06-2011 12:42 PM |
Anyone actually use frames mode on the video track? | Starcrash | Post - Surround - Video | 14 | 04-16-2007 09:09 AM |
a video brainteaser: frames and beats matching | sidereal-studios | Post - Surround - Video | 10 | 05-12-2004 10:57 AM |
video dropped frames in capture re-re-re visited | Michael Klinger | Pro Tools TDM Systems (Mac) | 2 | 01-25-2002 01:09 PM |
