How do i change my buffer size?
Purchased pro tools 9. Installed program but i am receiving a message stating
THE AUDIO DEVICE IS CONFIGURED WITH AN UNSUPPORTED AUDIO BUFFER SIZE. Go to the device control panel and select one of these sizes (32,64,128,256,1024,2048) 1. How do i locate the device control panel to select the proper size? 2. And what is the proper size? Using an in tell computer with Windows 7 Any help is truly appreciated. |
Re: How do i change my buffer size?
this has to do with your audio hardware. what interface are you using to get in and out of pro tools?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
How do I change my buffer size?
Purchased pro tools 9 for my intel which uses windows 7. once installed i received an error message statin:
THE AUDIO DEVICE IS CONFIGURED WITH AN UNSUPPORTED AUDIO BUFFER SIZE. GO TO DEVICE PANEL AND SELECT ONE OF THESE SIZES (32,64,128,256,512,1024,2048) 1. How do i locate the control panel to change the buffer size 2. What is the proper size to change it to Any help would be appreciated |
pre sonus
24bit/ 96k firewire recording interface firebox |
Open the utility for the Firebox and select one of those buffer values(you may need to select the same value in Pro Tools). There are often some little hurdles to using 3rd party interfaces
Re: How do I change my buffer size?
First try Pro Tools>Setup>Playback Engine. Start by selecting higher buffer size then try incrementally lowering.
Generally speaking, low buffers are better for recording (lower latency) high buffers are better when editing (less taxing on computer resource). It might help to give some more info on what outboard equipment you're using and your computer spec's; Windows users need to provide a Sandra report - Please - Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
just set it in the software for firebox. typically 64 for tracking and might raise it to 1024 for mixing depending on the power of the computer. it will automatically set these parameters in pro tools as it will slave to the hardware.
I have the Miko it uses presonus"FIREBOX' 24bit/96k firewire recording interface
Is this system even compatible with pro tools 9? |
Problem is I don't know how to step by step change it in the firebox. brand new to the whole system.
I can't even get into pro tools at all. it is saying i have to change the buffer size in my hardware before i can even enter the program and i do not know step by step how to do so.
Cant change buffer size | shea | Pro Tools 11 | 0 | 01-16-2014 11:38 AM |
So, When change H/W Buffer Size...... | gonsdeejay | Pro Tools 11 | 0 | 07-29-2013 09:12 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Can't Change Buffer Size? | sajack23 | Windows | 5 | 08-05-2012 05:29 PM |
PT9 / Buffer size won't change | narapo | Windows | 3 | 08-15-2011 02:59 PM |
