using a focusrite isa 428 with mbox 2
this may be an uneducated question, but I don't understand how to connect my focusrite isa 428 to the mbox in order to get the audio into the computer. My concept is that if I use the isa 428 as a preamp and I connect its output to the mbox, I would basically be using two preamps. Is this correct? How should I connect the two units? Please help.
Re: using a focusrite isa 428 with mbox 2
No problem.
You need cables to go from 428 out 1 & 2 to M-box in 1 & 2. You get line level signal from the 428 so be sure to select this at the M-box inputs. I have never seen an M-box (live) but I’m sure, you need 2 balanced cables with female XLR´s at the one end & TRS jacks at the other. Even better, if your 428 has digi card installed you could connect them digitally with the SP/dif cable.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Thank you so much, I really appreciate it.
You are welcome..
How is it going?
Focusrite vs. MBox? | danander11 | General Discussion | 3 | 09-14-2011 05:40 PM |
MBox 3 or a Focusrite ISA One | jimst57 | General Discussion | 3 | 01-25-2011 04:33 PM |
Connecting Focusrite to Mbox | Hanslemonverm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-05-2004 11:00 PM |
Mbox through focusrite voicemaster?? | I hate avril | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-27-2003 02:13 AM |
Mbox through focusrite voicemaster | I hate avril | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-25-2003 06:29 PM |
