Old 04-28-2013, 01:41 PM
mgmazzei mgmazzei is offline
Default Session ignores mic inputs
Here is one I cannot figure out.... One one of my sessions, when I connect a mic to any input(A, B etc...) it connects in the session without me connecting it to an input channel in Pro Tools!!! I have NO INPUT selected on the Aux or input channel BUT I hear the mic on that input!!! If I mute the channel, I still hear the mic!! If I select NO input on the channel, I still hear the mic!!! I can still record but the channel will not respond to mutes. This is happening on only one of my sessions. I created a new session and imported the session data to a new one but the problem still remains. Did I do some command that leaves the inputs OPEN? I hear the mic on input A or B and I have not yet assigned them to the input? only on this session??? any ideas???
Mike
Old 04-28-2013, 07:01 PM
anothercolour anothercolour is offline
Default Re: Session ignores mic inputs
Could it be because you have the "Input Only Monitoring" option on?
Look under Track > Input Only Monitoring. (Option+K on the Mac)
Old 04-29-2013, 09:08 AM
Hi anothercolour.. thanks for taking the time to reply... no, it's not that... I checked but that's not it... This is very strange... I hear the input from the mic (pre amp) without any input assignment. I can assign the input and PT does record but I cannot mute or really control anything except from the pre amp. If I create a new session I do not have this problem. It's just this session.. something is causing this.. I just can't figure it out. Thanks again for the input.
Mike [bleep]
Old 04-29-2013, 09:16 AM
Top Jimmy's Avatar
Hidden aux tracks could do this. Check the track list on the left side of the edit window to see if you have any hidden tracks. If so, show them and mute, deactivate or delete as appropriate.
Buttdialed by me & Tapatalk
James Cadwallader
Old 05-02-2013, 09:51 AM
Hi Top Jimmy,
Thanks for the help... I did have some hidden Aux inputs so I check them. They were off, but I reset them anyway. Now everything is working fine. I'm not sure if the reset on the aux's did anything, but things are good now. I have opened and closed the session several times and everything is working the way it should.
I'll keep both 'tips' in mind if I ever have this problem again.
Thanks,
Mike
ProTools ignores Limiter Ceiling Smico macOS 10 12-19-2013 02:50 PM
Nice find in PT8 - Waves ignores tab! timothyd4y Pro Tools TDM Systems (Mac) 5 12-23-2008 04:30 PM
PT ignores Play key, trash preferences? Travis_BCN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-20-2007 01:31 PM
BOUNCE IGNORES REGION AND RENDERS ENTIRE SESSION? chriswren1975 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-21-2006 03:28 PM
'Digidesign Ignores Matrox!' Read all about it! K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 46 11-21-2005 12:47 AM
