Old 02-13-2007, 07:19 PM
Andres Gonzalez Andres Gonzalez is offline
Default Keyboard shortcut for region deselect
If I have a region defined on one track, and I want the same region to be defined on another track, I use Shift-Click. I can add as many new tracks with the same region defined this way.
If I want to de-select the region in a track, I use Start+Alt+semi-colon and it will de-select THE LAST SELECTED REGION. How do I de-select an arbitrary region?
In other words, I define a region on track 1, Shift-click track 2 (the same region is defined on track 2), Shift-click track 3 (same thing happens). Then how do I de-select track 1?
Or better yet, I have a region defined on track 1 and I want the same region defined on track 3 AND NOT ON TRACK 1. That is, I want the same region defined on a different track plus I no longer want that region defined on the original track.
What is the keyboard shortcut for this?
Thanks,
-Andres
Old 02-13-2007, 07:36 PM
Stig Eliassen's Avatar
Default Re: Keyboard shortcut for region deselect
P moves the selection up, and I think Colon would move it down. I have a keyboard with norwegian keys and layout, so I'm not sure.
Old 02-13-2007, 07:47 PM
RobMacki RobMacki is offline
Thanks,
-Andres
I do this all the time comping VOs and especially rearranging OMFs.
To move a region to the exact spot on another track and delete it from the original track. (moving it to a track above)
The way I do it for example is:
'Selection'
'C'
'P'
'V'
'X' or Delete
It's a few strokes but it can be done quickly. I use two hands when doing the move.
When you have a selection the 'P" and the ';' will move the selection up and down.
Maybe someone has a quicker way or maybe Kenny will feature this on one of his ProTorials.
Old 02-15-2007, 10:49 AM
Thanks for the responses--I will try them out.
It was on his Beat Detective tutorial that I saw him move the selected region down and I tried to duplicate what he was doing but could not do the basic region move operation. It is very frustrating when a simple operation like moving regions gets in the way of the bigger picture.
-Andres
Old 02-15-2007, 08:06 PM
-Andres
His move was in Commands Focus (same as the one I described) only he was using the " key to navigate Tab to transient. (I believe)
The move he was doing was:
" (tab to transient)
P (up to replacement track)
V (paste)
; (down to drum track)
:|| (repeat)
Old 02-16-2007, 02:54 AM
NickH NickH is offline
I have always used the ‘Tab’ key for tab to transient, I was under the impression the key you mentioned was ‘Next Start End’ on the US keyboard…
Cheers
N
“It’s because you touch yourself at night... ”
System Specs
Old 02-16-2007, 11:25 AM
Cheers
N
When Tab to Transient box in the Edit Window is checked " & L will tab to transient rather than "Next/Previous Start/End" in Command Focus Mode.
Old 02-16-2007, 11:46 AM
How odd… it doesn’t do that on any of my machines… (Whether I am in command focus or not…)
And the reference guide only mentions the ‘Tab’ key
N
System Specs
Old 02-16-2007, 12:20 PM
N
Not sure if you're missing something or not but that's how it works here.
But if you notice in the Tutorial that Kenny uses BeatDetective to divide the performance into separate regions. Then you can use the formula above and it won't matter if you are in tab to transient or tab to region since the region is cut to the transient.
hth
Old 03-14-2018, 12:08 AM
ZdonTheRapper ZdonTheRapper is offline
'Selection'
'C'
'P'
'V'
'X' or Delete
you could just use cut which is x on protools instead of copy, then you could cut and paste instead of copy and paste, would be faster
Keyboard shortcut to show/hide region bin? Rich Breen Post - Surround - Video 8 02-09-2012 03:45 AM
keyboard shortcut for renaming region erocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-14-2010 02:47 PM
Keyboard Shortcut for region placement jamiecer Tips & Tricks 2 06-23-2008 08:50 AM
keyboard shortcut for hearing portion of a region? Avi Bortnick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2006 01:22 PM
deselect reigon from Keyboard Xplosvebob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-03-2002 12:11 AM
