Eleven Rack with PT 11
Since PT11 does not have an 11R window how do we import user presets in the 11R. I am new to the 11R, but found the site and tons of .tfx presets. If anyone has an idea on this that would be great. Thanks |
Re: 11rack with PT 11
you will need to use Pro Tools 10 to access the on-screen editor
Your PT11 license came with a bundled PT10 license, so it should not be any problem to install and use it. http://avid.force.com/pkb/articles/d...-3-8-Downloads
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
can the pt10 license be put on a separate ilok so I could use a laptop to control the 11 rack but still run 11 on the main computer?
Intel 4770K Hackintosh 16GB 128 SSD 770 GTX PT10 11 rack Mac mini ivy bridge i5, apogee quartet, PT10, 11 rack |
Thanks all, I found it...the trick is activate the a very simplistic 11R window found in Pro tools. Click the right top corner drop down menu and select Eleven. Once on it will appear far left top corner and current preset will be displayed. Then right click on preset patch and select the files you want to hear, test
and/or save. So, yes, 11R window and rig displays are gone (PT11) but the small transport window allows you to work with the presets. Thanks Sweet Water!! |
Nice Tip ! :) but a control window in Pro Tools 11 still a must
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.3 Pro Tools 2024.3 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
Then no additional iLok is needed PS. I only use PT8LE for the purpose of editing/storing 11R presets (no recording on that old laptop).
11R Mini Window.jpg However it does not allow you to adjust parameters, or save rigs to the computer. You can use it to adjust volume, Load Rigs from the computer, and change the active rig.
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Some experimental tracks using Eleven rack and Eleven RTAS | kittybite | Eleven Rack | 4 | 06-18-2013 12:18 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Eleven Plugin as Eleven Rack replacement | pureanalog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2010 01:57 AM |
