recording question new user. HELP!!!
Hi guys. So I bought a eleven rack second hand with out pro tools ( bad idea) I guess , because now I want to try and record something but I cant afford pro tools. I have reaper set up and I've recorded some tracks but here is the problem . Eleven rack sounds great (very analog not digital) through my combo amp and into my monitors, but when I run through the computer or use headphones it sounds very fizzy and digital like a cheap distortion pedal. Is there a clock setting or something that I need to change for recording or is it reaper. Just wondering if anyone has this problem or how they fixed it. I guess I can spend hours trying to eq the sh.... out of it to make sound good, but I hope there is an easier fix. Any suggestions would be appreciated thanks
That's what I heard about the Eleven Rack. It sounds good through the amp and monitor setup but not in the computer. If I'm correct, you need to tweak a whole bunch. Also, I believe people have presets that they set up already that you can get from them. There is an article on this somewhere. I'll try to find it.
Have you down a search in this forum for the Eleven Rack? I know someone asked that same question. Someone else will chime in. 📀
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
Re: recording question new user. HELP!!!
Did you turn elevenrack cab sim off when you used it with the amp?
If you have the cab bypassed while running through your power amp and cab then it is possible that you still have the cab bypassed while trying to record direct. This will obviously give a very bad and Lo-fi sound. I have a video where I am showing Redwirez impulse responses, and in that video there is a short section where you can hear the difference between the Eleven Rack with a cab and without, watch that video and if that is the sound you are getting, than you probably just need to re-enable the cab. https://www.youtube.com/watch?v=i5_JOAS9Mqc (about 1:40 is where you can hear the difference) If that is not the problem than it could be that you have dialed in tones that work while going through your amp/cab, but may not work well while going through the included cab/mic combos, so you may need to try to dial in some sounds from scratch using just the included amp/cab/mic/effects. You could also try using some of the thousands of free, user made Eleven Rack Rigs/Presets..... however, without Pro Tools, I guess you don't have a way to load downloaded presets on to your Eleven Rack...... If you do happen to get Pro Tools then there are thousands of free presets available. http://www.elevenrackpresets.com/ http://elevenrackusers.blogspot.com/...rack-rigs.html
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
You can use elevenhack to download presets to your eleven rack,elevenhack is a free (but i can donate) app. Made by a guy from the elevenrackpreset.com forum,it works great and with all the effort the guy Made to create it he deserve some adv and some donation too. |
OS 10.9.1 user trying to install Pro Tools Recording studio | kootenai1 | macOS | 7 | 01-27-2014 02:44 PM |
Separate user account for recording drive | kEVINT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-15-2011 09:00 PM |
Preroll Not Recording Before Insertion... User error? | Matt82au | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2010 06:21 PM |
? About SPDIF Mbox Recording From New P Tools User | adavis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-06-2005 08:28 PM |
HELP - New User Recording Set up | Zoduati | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-16-2003 07:38 AM |
