Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-13-2020, 04:34 PM
bleachbro bleachbro is offline
Default Cancelled Bounce Bug
When I have anything selected and I initiate Bounce dialog, and change my mind and hit Cancel, the audio that was selected is deleted!
If I undo, it returns. This happens every time and I've reported it to Avid. I tried on another system and it does not happen.
Avid tech cannot recreate. I did the pref/database delete etc no change.
This started in the last version update (2020.5 I think) or so. I'm running HDX on 5,1 running Sierra 10.12.6, and Eucon for S3, Dock and Control App.
Has anyone else ever seen this? Thanks for any help! This has bit me more than once if I forget to undo!!
Video...
https://we.tl/t-J47VtkLGu0
Old 07-13-2020, 06:52 PM
Progear Progear is offline
Default Re: Cancelled Bounce Bug
My brand new iMac i9 with a clean install with only pt2020.5 running , crashed almost every time i cancel bounce to disk. I have sonarworks as a plugin and always forget to bypass before i bounce..
It really sucks.
Old 07-13-2020, 07:06 PM
That helps (even though I'm sorry to hear that!) - So there's something going on here... Thanks for the reply!
Old 07-13-2020, 07:20 PM
cwsand's Avatar
cwsand cwsand is offline
Strange - not happening here on High Sierra.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-13-2020, 07:22 PM
Thanks for another clue, Chris.
Old 07-14-2020, 03:32 AM
nstu nstu is online now
It really sucks.
Will not help the OP but maybe you.
If you sum your mix to a final „2track-bus“ aux you can multi route that bus to a) listen bus with Sonarworks and b) bounce bus with another output. That way you never have to think about disables Sonarworks.
I also have a headphone bus to use Sonarworks with headphones. Just mute the bus you don’t wanna listen.
Gesendet von iPhone mit Tapatalk
Old 07-14-2020, 05:53 AM
Thanks great idea ...
Old 07-14-2020, 05:59 AM
JFreak's Avatar
JFreak JFreak is offline
Sierra is no longer supported, by the way...
Janne
Old 07-16-2020, 03:10 PM
100% right. And in this case - it matters. I upgraded to High Sierra and the bug is gone.
Thank you all for the help!
Old 07-16-2020, 03:11 PM
JFreak's Avatar
No problem
Janne
Avid Connect and NAB Show Participation Cancelled Avid General 1 03-11-2020 08:05 PM
Please Delete. Cancelled hatepop Buy & Sell 0 06-07-2015 03:00 PM
Nothing but Crashes and Cancelled Sessions thepurpleroom Pro Tools TDM Systems (Mac) 7 03-31-2011 03:47 PM
Accidently cancelled my download!!! Laughterbirth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-02-2009 04:04 PM
Waldorf Q tdm synth cancelled???? digiaudio Pro Tools TDM Systems (Mac) 20 02-05-2004 04:27 PM
