Old 07-07-2007, 04:44 PM
HJKL HJKL is offline
Default how can use all my delta 1010lt inputs in protools?
how can use all my delta 1010lt inputs in protools? i seem to only be able to use the mic input right now, or at least to NOT be able to use the RCA ins 3 and 4.
also, how can i use more inputs in parallel?
Intel D975XBX2K2 Motherboard
Delta 1010LT Soundcard
Protools Version 7.3.1
Old 07-07-2007, 05:34 PM
spkguitar's Avatar
Default Re: how can use all my delta 1010lt inputs in protools?
Sounds like you need to go into the I/O setup in Pro Tools and set you inputs and outputs to the default values for the 1010.
Old 07-13-2007, 10:02 PM
vjk vjk is offline
...Yep, that's the way to do it...
I use the Inserts from my Ymaha desk to the inputs of the DELTA 1010LT and set the I/O to Default in PTMP - all works fine.
I'm actually using inputs 3 to 8 at the moment, as I don't have any short XLR - Jack leads to get from Inserts 1+2 of the desk to the Female XLRs on the DELTA breakout cables - do I need any special leads for this, or just straight up Male XLR-Jack leads?
PT MP 7.3.1cs3,Delta 1010LT,Yamaha MG16/4, AudioTechnica 20/20,Behrenger C2 Mics,Shure SM58,Windows XP Pro,P45G Chipset,P4 3Ghz,2Gb RAM
Old 07-14-2007, 07:25 AM
mcgirr mcgirr is offline
I am not completely familiar w/ 10/10 lt.
I own the 10/10 rackmount.(one of the best converters made.)
But as an aside.. Radio shack sells just about any converter you could want.
In the past I have purchased xlr to 1/4" converters to utilize various pre amps on different units.
There are also 1/4' to rca and so on....
While the xlr to 1/4" converters are not cheap.(about $35.00 if I remember correctly.)
They are very usefull. I keep 4 or 5 in the studio for various reasons.
By putting these on the xlr breakouts on the 10/10 lt you can then utilize the xlr ins with other cord types. I believe they are balanced.(downside is they are a little large and a bit heavy. Dont leave them hanging from the back of the card.)
Hope this is usefull.
Best wishes.
Old 07-15-2007, 08:27 AM
Meta Meta is offline
In Pro Tools go to the top tool bar and look for I/O set up. Click that.
Make sure your input & output I/O set up is matched with your Delta 1010LT. You can also make sure it works by hitting the Default button on the bottom right hand side of the I/O set up menu. Once you have done that you will see the Input and Output slots of the I/O set up read the correct alignment with the Delta 1010LT.
Looking to move to PC so I can use a Delta 1010LT jj5000 Pro Tools M-Powered (Win) 2 12-09-2009 06:42 AM
Protools 7.4cs5/Delta 1010LT - sync to D1600 kiddstudios Pro Tools M-Powered (Win) 4 08-12-2008 12:20 PM
PT and Delta 1010LT ziggy1621 Pro Tools M-Powered (Win) 0 01-03-2008 06:26 PM
Delta 1010LT and 10.4.6 jbmelby Pro Tools M-Powered (Mac) 0 04-23-2006 09:33 AM
Delta 1010LT Hardware Help NoGreatMan Pro Tools M-Powered (Win) 2 12-01-2005 03:07 PM
