Old 11-19-2021, 01:07 PM
heisericsanderson heisericsanderson is offline
Default Carbon Latency on tracks routing to Sub Mixes
Hello,
This is my first post.
I have tried to trouble shoot this issue and reviewed the documentation on line.
Currently, Carbon's DSP Mode is working perfectly my tracks. There is zero latency when recording to a track that is sent to my main Monitor outputs. This is true of small and very large session.
My issue is I like to rout all of my tracks to a Sub Mix and then to a print track. The print track is an audio track that is routed to my main Monitor Outputs. This gives me the ability to reference other songs or other mixes by engaging/disengaging the input monitor for the Print track.
If I the track I am recording onto is routing to the Sub Mix, then any other track that is routed to the sub mix has latency when the track is in record mode.
I'm assuming there is a set up issue that I cannot find. Can you please help?
The only way I have found to work around this is the set the output of the track I am recording to, to my main monitor out. Then I have no latency issues but that does not seem like Carbons original intention.
Thank you,
Eric
Old 11-19-2021, 01:25 PM
Default Re: Carbon Latency on tracks routing to Sub Mixes
Welcome to the DUC!
Routing thru buses has often(always?) caused some latency issues. Some questions;
1-Are there any plugins on your "print" track? If yes, make them inactive while tracking.
2-Have you tried DSP-safe'ing the print track?
3-Would your world collapse if you changed your workflow? My 2 cents(and please take it that way), coming from the old days of mixing thru a console, I mix everything to the main outs(no print track) and Bounce to Disk without issue(the mix sounds the same as it did in the session and I avoid any chance of the issue you describe). This is not to say I have never used a print track as I have, but only to get around some other issue such as not being able to complete a BTD(aren't computers fun).
Not sure what your experience level is and no offense is intended, but there are a couple of facts to consider regarding latency and compensation and 1 important detail is that latency on a master track is NOT compensated for(so, depending on plugins and how you monitor, you can cause unintended latency. Another is that ADC works by pushing everything later to match the track with the most(some newbies think ADC is going to make things playback earlier).
Old 11-19-2021, 06:52 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Originally Posted by heisericsanderson View Post
Hello,
Thank you,
Eric
Eric, this is the way I always rolled with HD, so I follow the logic.
Are your tracks all showing green, including the bus and print track?
How much latency?
Remember, input monitored tracks aren't latency compensated with non-monitored tracks, too. In other words, if you put the Plugin-Alliance Purple compressor on one track and add 2ms latency, the other tracks aren't offset by that amount, unlike traditional HD workflow where your highest latency rec-enabled track was the system latency.
TDM rules apply here, though. No native plugins on busses record-enabled tracks are routed to, plus the bus delay is stacked with track delay.
Any native processing, on the other hand, IS delaying the buses by that amount (compensated), so a 5ms latency native plugin WILL delay your bus and print by 5ms.
Old 11-28-2021, 10:34 AM
K Roche's Avatar
K Roche K Roche is offline
I have never use a print track as a main sub bus for comparing to a reference track ??? .
What I do if I want a reference track to compare against.
Since I always route everything to a main sub bus or 2 Bus. Which is routed to my main outs via a Master Fader Then if I have a reference audio track I simply route it to the main outs also. Then I can just mute the 2 Bus track and unmute the reference track listen then mute it an unmute the 2 Bus
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
Can't record tracks in a routing folder due to latency [email protected] Pro Tools 2020 12 03-04-2021 02:06 PM
Pro Tools Carbon Latency Problem Chris August Pro Tools | Carbon 33 12-22-2020 09:46 AM
Tracking,Latency and Sub Mixes Studio66 Windows 9 12-19-2018 08:34 PM
Cue Mixes, low latency monitoring Tim Mayock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2008 05:00 PM
I have Latency on my Aux sub mixes!!!!!!!!!!! Brick Adams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-08-2008 03:02 AM
