Old 03-29-2016, 09:53 AM
marsian marsian is offline
Default Meters lag with OSX 10.11.4 and ProTools 12.5
Hey guys,
I installed PTHD 12.5 on OSX 10.11.4 on a second partition to test it.
So far it runs fine. The cpu-meters are a few percent lower than under PT11.3.2 on OSX 10.8.5, with the same session. PT is loading fast, especially the video engine is loading much faster than on earlier versions. The only bad thing are the PT meters on screen, which are lagging. They seem to be not accurate and slower than on PT11.3.2.
Does anybody have the same experience?
Cheers
Maik
PTHDN 11.3.2/12.5, HD OMNI, Sync HD, PT S3, OSX 10.8.5/10.11.4, MacPro 5,1 8core, 24GB RAM, AMD Radeon 5570, Blackmagic Decklink Extreme HD 3D Driver 10.6.2
Old 03-29-2016, 10:26 AM
Default Re: Meters lag with OSX 10.11.4 and ProTools 12.5
There are probably hundreds of posts on DUC about graphics issues with El Crapitan. Search will find them for you.
Old 03-29-2016, 10:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
Man that sucks for you Maik
With all of the Video fixes it's hard to drop back down to 10.8.5....but that's going to be your most stable setup.
My 12.4/5 setup at 10.10.5 is really good but no core audio support, so if you can live with that you should be good to down grade to 10.10.5 and you won't see those graphic issue with the meters
Daniel
Old 03-29-2016, 12:03 PM
Hi YYR123,
thanks for the hint. I'll try 10.10.5 next.
Cheers
Maik
Old 03-30-2016, 01:33 AM
Hi guys,
I sent it to AVID support. The answer was, that there are still issues with the GUI that should be fixed with the next release. I can't hear "next release" anymore. This is getting serious, because I don't want to pay that much annually for releases that are barely usable.
Cheers
Maik
Old 03-30-2016, 03:08 AM
...some more infos:
Lagging meters do only appear when AVID plugins are open (visible GUI of eg. ProComp, Dyn3). If the plugin GUI is closed the meters are acting normal and fast without lag. The lag does not appear with 3rd party plugins (eg. Nugen VisLM, NUGEN ISL2, Waves C4,Waves RenComp, FabFilter ProQ2).
Regards
Maik
Old 03-28-2020, 12:50 AM
Dany Richter Dany Richter is offline
Hi, did you get a solution for this? I´m experimenting the same meters lag on my Pro Tools 2019/Catalina system...
Originally Posted by marsian View Post
...some more infos:
Regards
Maik
HTML code is On
ProTools 11.3.1<->Steinbergh UR824 VU Meters Freeze rickc1967 Pro Tools 11 0 03-28-2015 12:04 PM
HD IO and ProTools meters are misleading tribase macOS 13 05-06-2012 12:33 PM
VU-meters in ProTools: any thoughts? Marco Migliari Pro Tools TDM Systems (Mac) 16 04-04-2003 08:15 AM
ProTools Record Meters, File System Mike Stosich Pro Tools TDM Systems (Win) 4 12-01-2002 02:38 PM
Clipping meters in protools Robot Sound Tips & Tricks 7 02-22-2001 11:15 AM
