Old 02-24-2010, 08:34 AM
subwoof subwoof is offline
Default D-Command Encoder
I seem to have a rotary encoder that will not go into update mode after the first pass of automation. All other pan encoders work fine, but fader 15 will only write the initial pass of fader automaton, but will not allow me to write any more updates. The amber automation led on that encoder will not go "red" when I touch it from then on. It does not seem to matter what mode of automaton I am in, including "write" mode. It will not allow itself to be updated. It seems to pass the fader test mode, but will not update after an initial write pass.
Any suggestions? Can a single encoder be replaced without sending the whole console somewhere?
Thanks
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 06-15-2010, 11:45 AM
mixermon mixermon is offline
Default Re: D-Command Encoder
If you nudge the track over to a different strip on the surface can you automate/update it? If not Check and make sure that the Track, Send, or plug-in is not in automation safe mode.
Digi 002 Console with Icon D-Command Encoder Knobs Benprogfuse ProControl, Control|24, Command|8 4 08-31-2012 03:09 PM
D-Command Encoder problem subwoof Pro Tools TDM Systems (Mac) 0 02-24-2010 11:51 AM
D-Command Pan Encoder Question Reckless Erik ICON & C|24 3 05-31-2007 02:57 PM
Rotary encoder error on D- Command Fader unit? tstemland ICON & C|24 3 05-02-2006 02:36 AM
Dithering question about SmartCode Encoder Encoder poldo Pro Tools TDM Systems (Mac) 4 05-30-2003 06:41 AM
