Old 09-07-2012, 01:56 PM
Featherstone Featherstone is offline
Question Trimming off unwanted time at the end of a track
I am bouncing down mixes and Ive noticed at the end of my track, there is unwanted time at the end of the track creating a long silence. For instance, if I end a track at 3 minutes and 35 seconds, there is an extra 6 to 8 seconds of silence after the track. Therefore, making every track longer than it should be. I have tried highlighting the extra time and hitting delete but it still leaves that extra time. Any suggestions on how to get rid of it? If every track I bounce down has extra time on the end, then there will be a long pause of silence in between every track on the cd. Please help.
Jeremy
Old 09-07-2012, 01:59 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Trimming off unwanted time at the end of a track
Try selecting the exact in and out point in your timeline and then bounce to disc..
You can also select in any track (start at the first point of your audio and drag your mouse until the end of the track-the point you want it to stop) It should just bounce what you have selected.
Old 09-07-2012, 02:46 PM
Stig Eliassen's Avatar
I suggest creating a selection memory location. That will make sure that each bounce has the same length.
Old 09-07-2012, 04:35 PM
The Weed's Avatar
The Weed The Weed is offline
Is Post Roll on?
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-07-2012, 04:49 PM
Drew Mazurek's Avatar
Mem Loc #99 is my "print" selection for every session I've done in the past 15 years.
www.drewmazurek.com
Old 09-07-2012, 05:19 PM
Right on. #50 is *PRINT*, and #51 is *EXPORT*.
Old 09-08-2012, 07:49 AM
PatriotsBiker PatriotsBiker is offline
What are you guys doing (or setting?) within the memory locations functionality to make playback, bouncing and recording stop at a specified time? I just read the chapter in the PDF PT reference guide and must have not interpretted what was written properly. I can't figure out how to use this to set a stopping point. I bet it's something very obvious and I'm missing it.
Old 09-08-2012, 08:12 AM
In the Mem Loc window, click the Selection option.
www.drewmazurek.com
Old 09-08-2012, 09:15 AM
WernerF WernerF is offline
Make a memory location point for the start of your song, then make a memory location point for the end of your song. After you have done that, hold down the shift key and click on the start marker and then the end marker. You will then have a selection that goes from start to end in your session timeline. Go from there.
Old 09-10-2012, 11:15 AM
Thanks for the tips.
Just so I'm clear, in order for the memory locations to actually function as start & stop markers, I need to select the two points just like I would select any two spots in the edit window and click play, record or bounce? Sort of just an easier way to select the section I want to playback?
Bounces selected track but shows remaining time of longest track mwsmith007 Tips & Tricks 5 01-06-2013 08:21 AM
It is Possible Trimming multiple Regions in the same track at once? AMIEL Pro Tools TDM Systems (Mac) 12 09-24-2010 07:52 AM
Help trimming down a track RettRobinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-26-2009 10:28 AM
unwanted noise in instrument track lechszcz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-01-2008 09:28 AM
Best ways to 'squash' unwanted excess reverb in precut track? Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-23-2001 11:55 AM
