11R - no main or headphone output
Stumped. Had been using this for years as my PT interface, was working fine this morning, now nothing. Have disconnected everything except guitar input (working as tuner works) and the xlr main outputs, switched 11R off & on. Checked mute options for both under user options, nothing!
ER Version 2.0.1, Build 0.1.5.7 Any ideas greatly appreciated. Reset? Laura. |
Re: 11R - no main or headphone output
You checked the mute options, but did you cycle them? If you turn the unit off with Mute engaged, the light isn't always on.
Are we talking no sound in standalone or with PT? If PT, default your IO. If nothing else works you can always reset the unit. Factory Reset https://www.youtube.com/watch?v=Lk5mzKoPOIw Manual Reset https://www.youtube.com/watch?v=GXTW5_A2C64
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thank you Benoni. The problem had started when connected to PT, hence I tried stand a lone. In the end switched it off and went and did something else for 30 mins and when I return and switch on its decided to start working again, so all reconnected.
What's frustrating is I have no idea what was going on for the next time :-( Thx again. |
It may have defaulted to the computer as the playback engine.....and that's why your headphones were muted.....
Monitor output or Main Analog Output? | A_alRumaidh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-17-2015 07:19 AM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
Help! I can't get my main output to work, and I can't make a stereo output! | oceanlove_1 | Pro Tools 9 | 1 | 06-27-2011 05:23 AM |
Headphone leakage to main monitor | Impala | ICON & C|24 | 0 | 09-16-2002 01:43 PM |
