Pro Tools 11.3.1 Error Codes -9171 -9172 -9173 -9129 -9093
Hello !
I am getting error codes -9171 -9172 -9173 -9129 -9093 I am running Mac Pro Early 2009 Processor 2.93 GHz Quad-Core Intel Xeon Memory 16GB 1066 MHz DDR3 ECC Graphics NVIDIA Ge Force GT 120 512 MB Software OS X 10.9.5 (13F34) Pro Tools HD 11.3.1 PCI HD Native Card (in slot 2) Avid HD IO 16/16 Analog I open a session and it idles around 20% then I play all the way through and the CPU shoots up to 100% and I get AAE 9173. The CPU then idles around 100%. Some times it falls back down to 20% but then when I press play, or arm a track to record it shoots back up and I get error codes. The H/W Buffer Size is set to 1024 (but Ive tried everything) and the cashe is set to 1GB (also have tried everything). I have tried doing a clean install of pro tools. I have tried getting rid of all the plugins (this makes the CPU go down but then when I add back even just the Avid plugins that come with pro tools the CPU shoots back up) I have tried getting rid of all elastic audio. I have taken the computer into the apple store and they throughly checked out the hardware and OS and found nothing wrong. Please!? Does anyone have any ideas of what I could try? I am pretty desperate. Thank you!! Best, Priya [email protected] |
Re: Pro Tools 11.3.1 Error Codes -9171 -9172 -9173 -9129 -9093
Not trying to be a smartass, but check the stickies at the top. Lots of us (all?) with your system (or very similar) are having those same issues... In the PT 11 | HD thread there is a hack that helped a few.
I have logged a bug report at Ideascale...maybe some votes would get it bumped up in prioirity.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Thanks for responding!!!
what is the link to ideascale? I only found bug reports for during bounce (error code AAE -9173), and that was supposedly fixed in 11.3.1 also is this the hack you were talking about? https://www.dropbox.com/s/g3f839lxsc...audio.txt?dl=0 The avid customer service people and I have started to get to know each other pretty well, hopefully the developers will figure out something soon because currently its basically impossible to work. .... ohhh I just found this http://protools.ideascale.com/a/dtd/153575-3779 was that you? thank you!!
Priya Mac Pro Early 2009 Processor 2.93 GHz Quad-Core Intel Xeon Memory 16 GB 1066 MHz DDR3 ECC Graphics NVIDIA GeForce GT 120 512 MB Software OS X 10.9.5 (13F34) Pro Tools HD 11.3.1 PCI HD Native Card (slot 2) Avid HD IO 16x16 Analog |
It's sansamp that's doing exactly this on mine. Dither plug before the sansamps seem to sort it out....
Not on mine, unless you have to take it out of the folder... but I WILL try that as a workaround.
Also, there is no point in trying to take PSA1 out of the plug-ins folder because it is an Avid plug-in and Pro Tools will just regenerate it when it opens (I think). Both Steve (the Avid person I was talking to) and I realize this is not a permanent fix however it made my sessions at least workable, which for me is a huge step. He took a lot of logs from my computer; when it was having the CPU spike, with the fix, and also took the session files that I was seeing the bug in, and submitted them to the developers so hopefully there will be a solution that has more finesse in the future. Please let me know if you hear anything new with this issue, and if this works for you. Good luck!!
You can find the Core PlugIns at: Pro Tools.app:Contents:PlugIns:Core Plug-Ins This must be done on each instance of Pro Tools 11, which means that when you update Pro Tools, you must re-perform this operation on the new version. If you do this before you ever run the new version of PT, you will not have those Core PlugIns installed in your PlugIns folder. I have also replaced all instances of SansAmp PSA1 with SofTube's Saturation Knob plug.
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
If this is indeed the case as a workaround, does this occur in the native version of the plugs? i.e. if I convert them to non dsp will they still fail? The thing that sux for me regarding this is, I usually use several if not 10's of those core plugs on any given session...to have to install dither on just every track I have a core plug on would be pretty expensive on the dsp engine...but if it's a viable work around, you have my devotion!
There is a lot of possible weirdness that can occur in strange places!
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
-9171 and -9172 errors Pro Tools 11 | HD | ArKay99 | Pro Tools HDX & HD Native Systems (Mac) | 117 | 01-03-2017 09:11 PM |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
Constant error 9171 & 9129 Pro Tools 10.3.2 | jsdetoro | macOS | 14 | 12-18-2012 07:57 PM |
Error codes -9093 & -9129 | metroGnome | Pro Tools TDM Systems (Mac) | 1 | 12-14-2000 10:29 PM |
