Old 01-27-2018, 12:55 AM
stakeoutstudios stakeoutstudios is offline
Default Pro Tools 2018.1 low latency monitoring issues
Has anyone else noticed problems with low latency monitoring in Pro Tools 2018.1?
I’m on a trash can Mac Pro with Sierra and Universal Audio Thunderbolt Apollos.
It seems to not work correctly (doubled sound as if it were off) then if you disable and re-enable LLM, it occasionally works as expected.
I’m doing my monitoring through Apollo DSP in Console.
Old 01-27-2018, 06:53 AM
john1192 john1192 is offline
Default Re: Pro Tools 2018.1 low latency monitoring issues
are the outputs your trying to use LLM on outputs 1&2 ??? could it be that when it works the tracks are set to this output and when they do NOT work they are set to something other than that ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-27-2018, 10:48 AM
No, it’s not a user error, or a different output. I’m used to how it works / should work.
It’s a fully re-produceable bug unique to 2018.1
If you press alt-k to initiate input monitoring mode it now disables low latency monitoring (although it’s still active in the menu)
Then if you disable and re-enable low latency monitoring, it works as expected.
I hope they fix this soon, I’ll log the bug shortly.
Jason
Old 01-27-2018, 10:50 AM
Jason
ok, and i will see if i can repro here .. i personally rarely ever use LLM ..thx for logging
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-27-2018, 01:53 PM
spock999 spock999 is offline
No Problem with Old MacPro 2008 under Yosemite using a UA Apollo Firewire
I will check on my friend's RIG with a MacMini Server Running El Capitain and using a New Apollo 16.
I know it's not the same setup but maybe it will help your Trouble shooting
Good Luck
Old 01-27-2018, 03:10 PM
ok, here is what i found .. i use my Lynx Mixer like you use Apollo Console ..
1) LLM disabled i hear the Doubling
2) LLM enabled i hear no Doubling, just my direct monitoring
3) LLM enabled, hit playback and i hear the track playing back then hit record, and i can then go in and out of record and punch in - hearing what is playing in Pre-Roll, then hear the Punch - my direct monitoring only, then hear the Post-Roll after recording ( i have pre and post on 1 bar) ...
4) LLM enabled, if i hit Alt-K to turn on Input Monitoring i hear Doubling, then turn that off and LLM is still enabled and the Doubling goes away
still not sure what i am doing wrong or what LLM is dpoing wrong .. this all seems correct to me ..
what recording Mode are you guys working in ?? Normal, Quickpunch, etc ?? maybe this is where the difference is ..
happy to be doing something wrong !!! just not sure what it is yet ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-27-2018, 03:18 PM
Thanks for that testing John, I wonder what is different about my system, it seems to be working correctly for you, but definitely not for me.
I’m usually working in quickpunch, I’ll experiment some more.
Old 01-27-2018, 03:26 PM
yeah, try not using QuickPunch for your tests ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-06-2018, 01:24 PM
Oufti Oufti is offline
Having the same issue here on PT2018/iMac 2012-HighSierra/Apollo 8p. The only turnaround I found is to open the Playback engine Dialog window, then click OK and everything is back to normal, as long as I record on the same track (the issue comes back when arming a new track for recording).
Old 02-06-2018, 05:27 PM
climber climber is offline
Did a lot of recording here and didn’t encounter this issue.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
low latency monitoring in Pro Tools 11 - IS THERE AN ANSWER ....? Zee&Eli Pro Tools 11 22 03-10-2017 07:23 AM
Low Latency Monitoring in Standard Pro Tools 9? Dizzi45Z Pro Tools 9 20 02-06-2012 08:55 PM
Pro Tools 9.0.5 - Low Latency Monitoring problem still persists xazqe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-02-2011 08:54 AM
Monitoring Latency issues 001 and Pro-Tools 6.4 LE eastwood1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 08-30-2006 01:04 AM
Pro Tools Free OS 9 monitoring latency - help!! sunlikeblood Digidesign Hardware & Software 2 12-29-2003 04:56 PM
