Old 08-18-2020, 12:43 PM
vieris vieris is offline
Default D-Control Fader alternative
Not sure if this has been discussed, but I just successfully replaced a few dying faders with Midas P&G clones. They work well. The fader throw is about a 16th of an inch shorter than the stock faders but doesn't affect usability. They fully CAL and report correct touch values. The only modification needed is to rearrange the connector pinout to match the color code of the stock faders, not difficult.
Under $200 for a set of 5 is hard to beat.
https://www.fullcompass.com/prod/561...d-100mm-faders
"Any experiment of interest in life will be carried out at your own expense."
Old 08-18-2020, 02:49 PM
Pete Gates Pete Gates is offline
Default Re: D-Control Fader alternative
Very interesting! Never heard of these. What's the feel like? I don't actually find the P&G faders that great for feel actually, nothing like the TKD faders in the S6 for example.
Pete
Old 08-18-2020, 03:01 PM
They feel ok, no better or worse than the P&G. They are not as smooth as the s6 faders, and nowhere near say the DFC / logic fader. That said they are better than sticky non-functioning p&g's
Old 08-19-2020, 10:41 AM
Sugarnutz Sugarnutz is offline
I’ve had my D-Command (Blue) switched off for a couple of months while I did some things. When I turned it back on I had TOUCH errors on half my faders and in my search for a solution I came across a post on the DUC from like 2013 for the Pro Control that said to rapidly press the CAL button up to 1000 times if needed. I did it about 40 times and all my TOUCH errors went away, don’t ask why but it did. This might save somebody some money maybe.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Alternative Control Surfaces innermusic ICON & C|24 3 03-24-2014 12:44 PM
Artist control alternative to SPL SMC ? yanos Post - Surround - Video 1 10-23-2011 04:49 AM
Alternative to Control 24 ?? marshallplexi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-28-2006 04:23 AM
alternative control boards? Canary green 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 10-06-2003 09:28 AM
cheap alternative to Machine Control seromaz Pro Tools TDM Systems (Mac) 1 01-24-2001 07:08 AM
