Eleven Rack knobs??
I've looked around for the knobs for the setting controls,there ones with the light showing through,and haven't found any.I may have overlooked them in my search but was wondering if anyone here could steer me in the right direction.
Re: Eleven Rack knobs??
Probably avid themselves - or at the least a registered hardware repair facility
The 'lights showing through' appear on different knobs depending on the parameters one has decided to change via scrolling through the menu.
Are you saying that no knobs light up to change any parameters having made a selection in the menu? For instance; Press and hold the Edit/Back button for a couple of seconds. Use the scroll knob to navigate through the menu to 'Rig Input'. Press the SW1 button. Does the second knob in from the left light up?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
It is not at all clear from your post what you are you trying to do. Is that to... work out what is wrong with an Eleven Rack? Replace a missing knob (and/or encoder?) on an Eleven Rack? Build something yourself with similar knobs? Are you after just the separate knob with light pipe? The LED Illumination? Optical Encoder? Potentiometer?
Yeah I know - it seems after I read Zed's that I might have misunderstood the posters intent....the mens rea
I have to admit, I was taking a stab in the dark, a case of RTFM?
Sorry about being kind of vague in my post,I need replacement knobs.
Try this - the site probably lists a couple of sites for repair replacement stuff, check there
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
PC main unit w/ clicky knobs want smooth knobs | Brandonx1 | ProControl, Control|24, Command|8 | 6 | 10-20-2008 11:34 AM |
002 rack replacement knobs? | J FRANK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-28-2008 08:49 AM |
