"Track could not be record enabled because..."
I am a newbie pro tools 11 user & I cannot record any tracks because I get the following message:
"Track could not be record enabled because it doesn't have an active input and output assigned." I've set my playback engine to my HW: Quad-Capture I've tried to default my input & output settings, to no avail. I don't see how to map the inputs & outputs to my Quad Capture (though both the input & output show "Quadcapture" at the top of screen box). I guess I don't understand how the I/O functions & I never had this problem with PT8LE. I've read multiple existing threads on this topic with no luck. Thanks for your help as always. pribb1 |
Re: "Track could not be record enabled because..."
The track needs an active Input and Output (look in mix window or have I/O showing in the edit window) This is required.
I think I figured it out. I opened an old session from PT 8 & I cannot record on the old PT 8 tracks but I can record if I add new tracks.
With the 8 session open, go to the I/O setup window and hit Default. That'll "connect" that session with your current hardware.
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack | spankyq | Pro Tools 10 | 8 | 04-20-2015 08:19 AM |
"The track could not be record enabled..." | Ewan T | Pro Tools 10 | 4 | 08-04-2013 07:06 PM |
Horrible Delay and Reverb on "record enabled" in PTLE 8.0 | jbandhisguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-28-2009 10:32 AM |
"Track" as a synonym for "record" | John Link | General Discussion | 2 | 08-19-2002 11:54 PM |
"auditioning" record-enabled tracks | markert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-10-2001 10:12 PM |
