Here\'s one I haven\'t seen....
Just got the Digi 001 - installed OK (Dell XPS-R 400/192mb - 98SE)- click on the icon to start it up - message reads: "Can't find cfd.dll file" - now in the folder right above the start PT/LE icon is that very file (cfd.dll) it can't find...and the 'find file' command has no problem finding it either...what gives?
Re: Here\'s one I haven\'t seen....
I've seen this happen when one of the PTLE's binary files (.EXE or .DLL) has been inadvertently copied to the desktop. Make sure the icon you're launching PTLE from is really a shortcut to the application, and is not the application .EXE file itself.
Eric Day DAE Engineer |
Nope...took the shortcut icon off the desktop entirely....launch from the folder icon still says it can't find the file directly above it and clearly visible...if only I could drag the file to the box and say, "there, stupid!"...
Any ideas? Can't evaluate a program I can't even get to launch... |
Voicecoop, see this thread below I think it may have an answer for you.
http://www.digidesign.com/ubb/Forum32/HTML/000042.html ------------------ RLM
Custom Built Intel Core2 Quad Q9550 Yorkfield 2.83GHz ASUS P5Q Deluxe LGA 775 Intel P45 Zalman CNPS9500 cooling Fan ASUS EAH3450 512MB Radeon 64 bit video SIIG 1394 PCI firewire Corsair 650 Watt power supply Corsair 4GB DDR2 1066 ram 2X Western Digital Caviar 640GB SATA 3.0Gb/s Lite-On 20x DVD-r Dual 22" Hannspree LCD Control 24/Digi 003R/PT10/RME ADI-8/Waves SSL/Waves Platinum/URS CSP/IK Total Studio 2 bundle/Massey/Strike/MPTK 1 |
voicecoop
I see this all the time. You must install the wavedriver 1.6 first then restart, then install Pro Tools ver 5.0.1 Win98SE. Follow that link for the PDF if you dont have the quickstart quide (chapter 3) for MAC and Windows. Also the document you need for installation of the wavedriver is on the Pro Tools ver.5.0.1 CD in the wave driver folder (Print and have ready) First de-install Pro Tools and Digisystem files remove the device in the system control panel under sound video and game controllers. Restart. Check under devices ( system control panel ) then click computer/properties and view the devices resoures( IRQ's) verify the 001 is not sharing with other devices( should be on the same IRQ with holder for PCI steering. If sharing, then move the card to another slot( may be bios congfigured) Let me know what you find after these steps. MJ Digidesign Tech Support |
