Old 01-14-2007, 02:49 PM
Chuck5021 Chuck5021 is offline
Default DAE 7401 - Can\'t find any info so far!
Hi There,
Just working on getting a new laptop going and am encountering a new DAE Error. It's #7401 and I get the following dialog upon trying to add plugins on a track's insert:
"Plugin could not be made active because DAE Error (7401) encountered".
The plugin is then made inactive. So far it's done it with most of my EQ plugs, and the L1. I did a search on the DUC and didn't get any hits on this error. Anybody have some insight? I've got a project due tomorrow and was hoping I could use this new laptop for it.
Here are the specs and info:
PT 7.0 (should i move to 7.1?)
Dell Inspiron 6400
Intel Centrino Duo at 2ghz
2 gigs ram
I've ran PT with 2 processors, and 1 processor with various anounts of CPU usage and buffer settings. Occasionally a reboot or setting change will make the problem disapear but it's only for a few minutes.
Anyone have some ideas?
Chuck Ibey
Greedy Productions
IMDB Page
Credits
Old 01-14-2007, 02:59 PM
scottedog scottedog is offline
Default Re: DAE 7401 - Can\'t find any info so far!
Try the Answerbase search.
Scott.
ScottedogStudios on ReverbNation
Old 01-14-2007, 03:05 PM
Thanks, I'll look right now!
Chuck Ibey
Greedy Productions
IMDB Page
Credits
Old 01-14-2007, 03:12 PM
I found one suggestion there. I'm going to update my ilok drivers and hopefully that will get rid of the error.
In the meantime I actually found a workaround.. If I already have a plugin active that I want to use, rather than opening it on another track I simply drag and copy to the new track. No error! It's just getting the first instance of the plugin to open that's causing frustration.
Chuck Ibey
Greedy Productions
IMDB Page
Credits
Old 01-14-2007, 07:04 PM
x9blade x9blade is offline
have you tried trasing all digidatabase and preferences folders?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Can someone tell me please? Can't find the info nowhere? M2E Pro Tools TDM Systems (Mac) 4 04-18-2009 07:10 PM
Where can I find info to chop up Trident? Drive d General Discussion 3 08-12-2006 10:51 AM
Where do I find "Reason" info? Anyone? grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-31-2004 10:25 PM
Where can i find more info about DVD authoring? Heaven Pro Tools TDM Systems (Mac) 1 01-04-2004 07:43 PM
WHERE CAN I FIND THIS INFO!?!? regis Pro Tools TDM Systems (Mac) 0 12-13-2001 11:49 PM
