Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-13-2020, 08:18 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default PT Auto-restarting After Quitting
Hey guys,
I'm getting this problem with PT2020.5 auto-starting after I've quit. It doesn't open fully and I can easily close it the 2nd time, and it remains closed.
I haven't had the time to do intensive troubleshooting but it looks like a corrupt session because it only seems to happen with one 90-track session. I know what to do if that is the problem, but this is the second time I've had this issue in PT2020 (2020.3 with a different session).
I have never experienced this before 2020, and I'd like to know if anyone else has seen this, and any likely causes.
Thanks.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 07-13-2020, 08:26 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: PT Auto-restarting After Quitting
If you suspect corrupt session, then does this happen when you first close session and then quit PT or only when you quit while the session is open?
Janne
Old 07-13-2020, 11:17 PM
lesbrunn's Avatar
Thanks, Janne. I realized it was still happening with the session closed. Trashing prefs sorted it out. Do you know what the cause could be?
Old 07-13-2020, 11:19 PM
JFreak's Avatar
Corrupt prefs file obviously. Knock on wood it has never happened to me, but it is possible
Janne
002 computer restarting jigman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2012 11:26 AM
HELP! 002 restarting Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-08-2008 06:46 PM
WHY DO I KEEP RESTARTING lil'slow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-18-2006 05:33 PM
Computer Keeps Restarting... Auralex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-07-2005 09:09 PM
URGENT HELP!!! RESTARTING!!! JBone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-15-2004 02:17 PM
