Timing issues printing through bus sends?
Hi all,
I'm having a strange issue and wondering if anyone has any words of wisdom? I'm trying to print effected audio from one track to another via a bus send. Specifically it's pitch corrected audio in Melodyne. I'm finding, when I do this though the timing is always slightly off, in the range of roughly 35 samples at 96k. I've been experimenting with turning Delay Compensation off, or leaving it on and bypassing the cmp setting on the tracks. I've also gone as far as making every other track in the session inactive and lowering the buffer to 256. There are no other plugins on and no other bus sends, etc... just the two tracks with one instance of Melodyne. I also tried routing via a "send" vs the track's output set to the bus. The pointed track actually has the newly recorded audio file showing before the original on the timeline in ever instance. Any thoughts? Thanks in advance! Tom Mac OS 10.11.6, 2010 cheese grater dual quad core 2.4, Pro Tools Ultimate 2018.12.0, 24GB RAM, HDX1 |
Re: Timing issues printing through bus sends?
Do freeze or commit also result in the same outcome?
I would suspect Melodyne as the culprit. Perhaps even something odd going on as the audio was captured. Run a test on a new track with a snippet of audio. Turn off delay compensation and capture it with Melodyne and then see if it too is ahead. Sent from my iPad using Tapatalk
Printing Shift in timing | Pariscope | Pro Tools 12 | 8 | 11-03-2017 06:50 PM |
Offline bounce not printing Aux sends [resolved] | aperez | Pro Tools 11 | 14 | 07-30-2015 05:08 AM |
Timing issues | GregV | Pro Tools 10 | 0 | 01-14-2015 11:29 PM |
Crashes & Printing Issues w/ PT 8.0.3, Waves 7.0.1 on SL | acacia | Pro Tools TDM Systems (Mac) | 6 | 01-13-2010 11:09 AM |
Put timing plugin on a buss coming from aux sends? | MixerGuy | Pro Tools TDM Systems (Mac) | 1 | 10-18-2005 11:57 PM |
