Old 07-19-2010, 05:26 PM
EarBud EarBud is offline
Arrow Ditch Reason Adapted / BFD Lite?
I'm getting ready to upgrade from PT 7.3 to PT 8.
I presently have Reason Adapted and BFD Lite (the freebie versions that were included with 7.3) installed, but after reading about the new AIR VI's that are included with 8.0, it doesn't sound like I'd be missing anything by abandoning these programs (BFD Lite was always buggy anyway, at least for me). The AIR instruments sound like they're far superior. Is this correct?
Thanks.
CPU: i7 950
MB: GA-X58A-UD3R
OS: W7 Professional 64-Bit / SP1
RAM: Corsair Dominator CMP12GX3M3A1600C9 (12Gb)
CLR: Prolimatech Megahalems + San Ace 9G1212H101 (x2)
HD: WD Caviar Black 500Gb (x1), WD Caviar Black 1Tb (x3)
OD: Lite-On IHAS424-98 R
GFX: PNY nVidia Quadro FX580
PS: Corsair HX850
CASE: SilverStone FT-02B
PT: v.10.3.9 / 11.3
I/F: Digi 002
Old 07-19-2010, 07:05 PM
browniespeaks browniespeaks is offline
Default Re: Ditch Reason Adapted / BFD Lite?
The avid drum solutions that come with 8 are less than adequate. I also like reason rex2 playback over PT native rex support. The reason drum machine (forget the real name) still has that ez to use step sequencer feel.
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 07-19-2010, 07:25 PM
Linhardt Linhardt is offline
If you were also adding Strike and Transfuser I would say you could dump the old lite apps, but as it is you may want to hang on to them for a bit. The VI's that come with 8 are nice, but Boom only fills a very tiny niche drum-wise. There are several kits in Xpand2 as well, though...decent, but nothing mind blowing. Meh, hard to say. I'd keep them for now and let your ears figure out what you want to use.
Darth Hobo, Dark Lord of the Synth
Old 07-20-2010, 12:29 AM
Top Jimmy's Avatar
Not a lot of people know that rx2 files can be loaded and played in all versions of Structure. Plus, the slices can be played individually and you can also rearrange them in the sequencer.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 07-20-2010, 04:34 AM
thenassaproject's Avatar
thenassaproject thenassaproject is offline
Thumbs up Re: Ditch Reason Adapted / BFD Lite?
I have air's Pt expansion pack and it comes with transfuser which is superior to redrum as a drum sequencer, and also strike which is a virtual drum machine that sound like a professional drummer with adjustable patterns, timbre, and complexity. For drums, the PTIEP is pretty much loaded. As far as matches for reason's synths, the PTIEP comes with Hybrid which is a pretty good triple oscillating synth with a sequencer. It also has a great sampler (Structure full) and an adequate ep.
Old 07-20-2010, 06:00 PM
Thanks!
I guess I'll leave Reason Adapted intact. I pulled it up and started playing with it, and you're right, there are some nice things about it that I'd forgotten about.
The AIR PT Expansion Pack sounds nice. Maybe I'll go for it, too.
Thanks again all for the input!
CPU: i7 950
MB: GA-X58A-UD3R
PS: Corsair HX850
PT: v.10.3.9 / 11.3
I/F: Digi 002
Live Lite 6.0 & Reason adapted w/PTLE 7.4 Vista casperfun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-02-2007 06:06 AM
ugrading reason adapted 2.5 to reason adapted 3.0 jimmyd3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2007 06:10 PM
PT and REASON ADAPTED / LIVE LITE vjk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2007 08:36 PM
Reason Adapted vs Not-Adapted...how does it work? arthur s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-10-2006 01:22 PM
Upgrade PT Reason Adapted to FULL Reason ...Price? bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2003 07:04 AM
