Old 06-09-2011, 08:18 PM
nerdlinger nerdlinger is offline
Default Need a replacement monitor pot for Control 24
The monitor pot on my Control 24 doesn't adjust the volume smoothly anymore. It jumps from too soft to too loud with very little rotation.
Does anyone know where I can get a new pot?
Thanks!
Old 06-14-2011, 04:39 PM
Lizardpoint Lizardpoint is offline
Default Re: Need a replacement monitor pot for Control 24
Hi Nerdlinger,
The monitor level control is digital rather than analogue.
My pot makes the volume jump in steps but they are acceptable steps at the moment.
I thin you may have a monitor board problem.
This is a complete PITA to change.
If you're not using the aux montors outputs then I'd plug your main monitors into this output and use the other pot.
If that pot's levels are jumping too then it's even more likely you have a monitor board fault.
Sorry to be the bearer of potentially bad news...
Lizardpoint
Old 06-17-2011, 02:13 AM
Thanks Lizardpoint.
I'll try the Aux Monitor output and see what it's doing.
Old 10-21-2011, 05:57 AM
GuyPicks GuyPicks is offline
Just saw this post: http://duc.avid.com/showthread.php?t=230175 for documents.
Thanks,
Guy
System 1---------------------System 2
MacPro 5,1---------------------------Windows 10
2-CPUs-------------------------------i7-CPU
OS X 10.14--------------------------Pro Tools 2019.5 HD
PreSonus 1824c --------------------HDX / 192 Analog
Fader Port---------------------------2-24" monitors
NI S61mkII--------------------------32GB Ram
64GB Ram---------------------------4 internal Drives
5-Glyph Rack Drives----------------Presonus 192 Mobile
2-24" Monitors----------------------Nektar Impact LX88+
Glyph Raid 4
Control 24 PSU replacement instructions bobson ICON & C|24 15 07-05-2015 03:02 AM
A simple replacement for Control 24 Matt Phat Getting Started 5 07-05-2013 12:25 PM
PSU, Monitor Board and Fader replacement instructions? Armando ICON & C|24 36 01-14-2012 09:49 AM
Replacement monitor arms for D-Control Console quadraphonics Post - Surround - Video 0 01-10-2012 06:45 AM
Fader Replacement Control 24 gabrieljay ICON & C|24 0 10-26-2010 06:22 PM
