Pro Tools Freezing When Closing and Quitting
When I close my session, Pro Tools beach balls and takes ah minute, sometimes 2 to close.
If I quit Pro Tools it does the same thing. Also, in one of my other sessions, when I select a track at any point to edit, its size goes medium, and it centers on the screen. I'm sure this is a shortcut I've hit by accident. I haven't figured which one it is though. If anyone can help me with one or both of the problems, I'd appreciate it. Thanks in advance. I'm running: Pro Tools 7.3.1 HD3, 96 I/O Mac OS X, V 10.4.9 2 X 2.66 Dual Core Intel Xeon 1 GB 667 MHX DDR 2 FB-DIMM |
Re: Pro Tools Freezing When Closing and Quitting
Please start with the steps in the OS X Setup and General Troubleshooting sticky at the top of this forum, specifically those areas on trashing preference and database files.
You may want to look at the Help us help you thread as well. |
You need to up your ram,I use too have the same problem untill I went from 2GHz to four GHz,even with all kinds of stuff going on/multiple eqs,compressor ect.I no longer have that problem,seriously get you some more ram and you will o.k
You need to up your ram,I use too have the same problem untill I went from 2GHz to four GHz,even with all kinds of stuff going on/multiple eqs,compressor ect.I no longer have that problem,seriously get you some more ram and you will o.kIm running Pro tools 8.04 M powered
Protools closing/quitting on it's own. | Ian Bodzasi | macOS | 17 | 11-24-2014 07:43 AM |
protools freezing when closing | jackp | Pro Tools TDM Systems (Win) | 5 | 03-02-2011 08:32 AM |
Just upgraded to Leopard, PT freezing and closing while starting | andydunham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-08-2008 09:24 PM |
PT7 Quitting when closing sessions | crizdee | Pro Tools TDM Systems (Mac) | 0 | 11-20-2005 06:00 PM |
Freezing when Quitting ProTools | mentalmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2003 12:35 AM |
