Sizing the Splash Screen.
I can't seem to find anyone who can tell me how to go about sizing the Splash Screen. (I think that's what you call it?) Its the backing screen behind the Edit and Mix windows in Pro tools. By the way I'm Windows 7. On my pc I have a top tool bar and the part of the screen in question, the File, Edit, Track, etc. selections, are partially hidden behind it. Some times it's difficult to mouse click precisely on the proper selection when I'm in a hurry. Basic pc 101 I know but I didn't get it in class! Thanks for putting up with my ignorance! I appreciate your help.
Re: Sizing the Splash Screen.
Terry I think that partially the back grey screen is a byproduct of the default resolution of your computers graphics -
So you can also play with that setting if some controls don't appear on screen ! Cheers
Hey Manny, Your suggestion worked for me on a 2 monitor setup, but as you said, you do have to move the mix and edit windows around for a new session or when opening up old sessions for the first time. The Ctrl-F5 is to zoom the edit window, so there must be some other command to save the configuration. I clicked on Help-Keyboard Shortcuts and got the message: Could not find help file "windows Shortcuts.pdf", so I will have to look for it manually.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Thanks many, Emcha audio. I'll try your method. I gave up on the 2 screen boogie and went to a larger, flat screen monitor. I am also wondering if there is a way to just eliminate the top Windows tool bar but be able to bring it back on demand by mousing to the top of the screen?
There's a member on here called guitardom and he's made a program called Skootch which is great for getting the screen sorted how you like. I use it for three monitors and couldn't use pro tools without it now :)
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Hey Terry, I also am running a 32" LED TV as my main screen Re the Windows toolbar, if you right-click on it and select Properties, there is a check box for Auto-Hide. That makes it disappear until you mouse to the edge where it lives(and it can live on any edge-top, bottom or either side). Having said that, I found it somewhat of a PITA as it kept popping up whenever my mouse got near it, so I gave up and leave it showing at the bottom of the screen
BTW, what you called the splash screen is actually called the "parent" window. The real "splash screen" is the first PT logo that appears when you open the program Not sure how you go about switching between MIX and EDIT windows, but I love my little Presonus Faderport as it has buttons on it to select the window. One of the best $120 I ever spent(right behind a UPS for the computer)
Get the windows where you want them then close with alt>F4. It SHOULD store your window positions.
It does indeed for me(and has for years)
Thanks everyone who responded to this. albee. parent screen. Got it! I'm gonna' try your method of hiding the tool bar unless needed. I usually just mouse to the Window heading on the PT's tools bar and select back and forth between Mix And Edit to choose the one I want to view. albee. is the Presonus Faderport an interface? Thanks
Pt 11.1 will not load past splash screen | Norrie | macOS | 15 | 01-15-2014 08:29 AM |
Load Splash Screen | Black Day | Pro Tools 10 | 2 | 02-10-2013 09:00 AM |
PT LE 8.0.5 No Launch, not even splash screen... | Dan.TweekStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-04-2013 08:56 PM |
Upgraded to PT 9.0.6 and splash screen still shows 9.0.5 | MotifMan | Windows | 2 | 06-21-2012 01:42 PM |
PT 8.0.3 splash screen. | TVPostSound | Tips & Tricks | 8 | 12-22-2009 08:00 AM |
