Old 07-10-2011, 05:40 PM
PT8716 PT8716 is offline
Default Akai MPD 18 in M-powered 8?
is it compatable?
Old 07-11-2011, 09:34 PM
Julia B Julia B is offline
Default Re: Akai MPD 18 in M-powered 8?
It's just a midi controller. Shouldn't be a problem.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 07-12-2011, 04:32 PM
it only has a usb out not midi. Will it work?
Old 07-13-2011, 11:58 AM
SSE4.2 SSE4.2 is offline
http://www.midi.org/aboutmidi/tut_midicables.php
Old 07-15-2011, 12:28 AM
My question should be "If I am using M-powered will Pro Tools recognize a usb midi device that isn't M-audio?"
Old 07-17-2011, 10:51 AM
scenicrecords scenicrecords is offline
Yes. It is compatible. I use that setup all the time.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Alesis QX49, Akai Pro MPD18 & pro tools m powered will they work? mattshee643 Pro Tools M-Powered (Win) 0 02-17-2012 01:39 PM
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 09:24 AM
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? jeremiah0812 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2010 10:10 AM
Trouble Syncing Akai MPC500 with PT M-Powered 7.4.2 eXeMt MIDI 5 07-11-2008 07:32 PM
PT M-Powered with FW400 bus powered audio drive? bruceup Pro Tools M-Powered (Mac) 5 07-06-2006 01:32 PM
