Transfuser Pad to Note Assignment!
A lot of people complain about the 12 pad limitation. If you want more pads just open another channel - problem is that another midi channel is needed. Hence you can't access more than 12 sounds at a time. Imagine if we could simply choose the octave - just that - change NOTHING else in transfuser. We would be able, using one midi channel, to access a whole keyboard full of sounds! One drum pad instance per octave as it is now! Add more for as many octaves you need to fill your controller up! It would make a WORLD OF DIFFERENCE!
Re: Transfuser Pad to Note Assignment!
To make it more clear, I mean having the option to change the octave per drum instance, not globally.
Its amazing how few people care. Access to just 12 sounds is all you guys need? And how can someone get in touch with the air group?!
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
installing Transfuser full on Transfuser trial | wfasano | Virtual Instruments | 2 | 06-30-2009 03:14 AM |
transfuser trigger pad midi assignment | johnbhoy | Virtual Instruments | 1 | 01-17-2009 03:54 PM |
EXPORT MIDI from Stryke NOTE FOR NOTE... |
riggi | Virtual Instruments | 1 | 03-10-2008 07:32 PM |
Pro-Tools Note-Event (Note-off Velocity?) | xytsrm | Pro Tools M-Powered (Win) | 2 | 01-10-2006 08:02 PM |
